Old 07-03-2011, 09:20 PM   #1
falkor_99
falkor_99's Avatar
Drives: 07 Yaris Blue HB
Send a message via AIM to falkor_99
100K check up question
So recently my Yaris just got 100K. I was wondering what are some of the things I should check on. I am going to change the spark plugs, cabin filter. The intake is new and I changed the oil and oil filter. Is there anything major I should check.
Also, I went 30 miles on 1 bar of gas and I was driving like I usually do. Tires are fully inflated, if anyone has any ideas about that, it would be much appreciated.
falkor_99 is offline   Reply With Quote
Old 07-03-2011, 11:47 PM   #2
swidd
Drives: Yaris HB
replace coolant? I hope you've changed gear oil before; every 30k miles with MT-90 redline. spray some MAF sensor cleaner.
Old 07-04-2011, 02:26 AM   #3
MickZEL
MickZEL's Avatar
Drives: Yaris sedan
Check the brake fluid. It should be clear.
Replace the filter gas in a tank of .
MickZEL is offline   Reply With Quote
Old 07-05-2011, 05:37 AM   #4
bankrobber
Drives: 2007 Yaris Hatchback
Umm, what...
bankrobber is offline   Reply With Quote
Old 07-04-2011, 10:33 PM   #5
Kiteless
Kiteless's Avatar
Drives: US 2007 Yaris Liftback 5MT
2007 does not have a cabin filter...
2007 Toyota Yaris Liftback Base 5 Speed.
Mods: Netz/Vitz/RS badging, RS style spoiler, RS replica tails, Tenabe NT210 Springs, Tokico Blue Struts, Team Dynamics 14", fogs(Arrived), JDM HKS Exhaust.
Kiteless is offline   Reply With Quote
Old 07-05-2011, 05:36 AM   #6
bankrobber
Because Toyota is too cheap to include it new. It does have a place for the filter. Though I have never bothered to put one in. No problems at 114K miles
Old 07-08-2011, 06:24 PM   #7
Kiteless
Kiteless's Avatar
RRRrrrrreeeeallllyyyy!? Maybe I should snag one. Its behind the glove box right?
- Jason
Old 07-05-2011, 05:17 AM   #8
bronsin
bronsin's Avatar
Did you do the valve clearance check at 60,000?
Its involved and since almost no other car has shimmed valves like the ECHO and Yaris, I question whether there are any mechanics qualified to do it. I suspect they take your car, dont do the work, then say "It was good!"
Needs new plugs at 100k also.
Old 07-08-2011, 07:11 PM   #9
thepartsmancometh
Drives: '08 LB, '07 WRX
e46 bmw m3 has shimmed valves. they get adjusted every 30k.....veeeery expensive maintenance. anyway, there are techs out there that know how to do it, and most good techs can do it with the appropriate instructions and some time and patience
thepartsmancometh is offline   Reply With Quote
Old 07-11-2011, 01:14 PM   #10
falkor_99
falkor_99's Avatar
All good stuff guys. But what about the transmission fluid. I have an automatic, so I wasn't sure when that should be changed?
Old 07-12-2011, 01:25 AM   #11
Astroman
Modded Moderator
Astroman's Avatar
Yes do that as well. I'm at 99,873 miles and will be at 100k in a day or so. Make sure to get the GENUINE AFT fluid from toyota. The automatic yaris can't use the stuff you get at autozone. Also replace the transmission filter. Don't get that from the dealer (It's about $85), I got mine at autozone for less than $19. Make sure with plugs to get the iridium plugs. No need to replace the fuel filter unless you have a problem. Reason is that it's located in the gas tank and part of the pump. My mechanic looked it up and its pretty spendy. He said I didn't need to replace it unless I was having problems.
Old 07-12-2011, 06:23 AM   #12
bronsin
bronsin's Avatar
Check the owners manual. But I believe the answer is: never.
Old 07-18-2011, 05:18 PM   #13
Astroman
Modded Moderator
Astroman's Avatar
It does need replacing.
Old 07-12-2011, 06:22 AM   #14
bronsin
bronsin's Avatar
I would find one of those to take my ECHO/Yaris to.
A home mechanic can CHECK the clearances themselves . Its not hard. Its ADJUSTING them where the problems come in.
Usually checking is all thats needed. But if tight exhaust valves are found that is motivation to find a mechanic to do the work...
Old 07-08-2011, 03:39 PM   #15
Red Horse
Red Horse's Avatar
Drives: 2008 Yaris sedan A/T
some1 make a diy to replace the gasfilter
Old 07-12-2011, 07:37 AM   #16
thepartsmancometh
the yaris calls for toyota WS (world standard) ATF. The only non-toyota fluid that I know of that isw compatible is BG's universal synthetic. It meets the spec
Transmission Question CMR General Yaris / Vitz Discussion 42 04-14-2010 12:38 PM
So question here abt hatchs in general Jem_hadar General Yaris / Vitz Discussion 12 01-06-2009 03:06 AM
Amplifier Watt Question....noob question hasher22 In Car Entertainment + Electronics (audio / video / alarm) 4 09-27-2007 03:59 PM
Paying for the Yaris with a check? YotaYarisUSA New YARIS Purchase Forum 15 07-11-2007 03:31 PM
Question about 2 kinds of TRD springs & rear strut bar Astroman Wheels, Tires and Suspension Forum sponsored by The Tire Rack 3 06-18-2007 05:44 PM
