Old 09-01-2011, 01:52 AM   #1
BennyLava
Drives: 1987 Silverado
My headlight got water in it!
My passenger side headlight on my 2009 yaris sedan got some rain or something in it. How can I get it out? It has been a few weeks and its still in there. Also, how can I seal it up? Maybe use some exterior automotive silicon from autozone?
Also what is the procedure for removing the headlight? Is it easy?
BennyLava is offline   Reply With Quote
Old 09-01-2011, 03:58 AM   #2
SilverBack
Joey
SilverBack's Avatar
Drives: '14 Scion xD 5-speed
1. Remove the lightbulb (may not be easy) and place on a nearby surface without the bulb's glass touching anything.
2. Remove the the headlight unit.
3. Using a blow dryer, melt the glue that holds the glass slightly just enough to release the glass lens from the housing.
4. Drain and dry-out the housing and lens.
5. Use the blow-dryer again to melt the glue on both the housing and the lens.
6. Place them together for a few minutes until they dry.
7. Re-install unit.
8. Re-install light bulb.
I'm sure that's all there is to it, but there might some stuff I left out. Someone here will chime in.
Old 09-01-2011, 09:02 PM   #3
BennyLava
Wow so you don't actually take out the whole headlight itself. I might feel more comfortable doing this if I removed the whole headlight though.
Old 09-01-2011, 09:25 PM   #4
SilverBack
Joey
SilverBack's Avatar
You do have to remove the whole headlight.
Also like I said, I may have left-out some info. There are people here who have done this lots of times, so it would help you out alot to use the search link at the top of this page (just to be sure you're doing the job right).
Old 09-01-2011, 09:50 PM   #5
AppleJacks716
Drives: 2010 5 Door
Im not sure how well a hair drier will work. I used an oven at 200 degrees and i was still wrestling it apart. My suggestion is to remove the headlight from the car. Pull out all the bulbs, drain the excess water and blow hot air into the back of the headlight.
AppleJacks716 is offline   Reply With Quote
Old 09-02-2011, 12:06 AM   #6
BennyLava
Ok well what about preventing it from happening again? New glue?
Old 09-02-2011, 12:08 AM   #7
Lil Abner
Drives: 2009 3dr LB Manual
Yeah, I also had a bugger of a time pulling it apart even after using an oven.
Try what AppleJacks said, get all the water out and blow hot air inside. Maybe do this indoors where it's not humid. Then once it's all clean, you could run a bead of silicone around the headlight between the clear cover and the black back. Also check that your bulb holders are sealed properly. They should all have o-rings around them, and NOT be easy to twist out of the light. Then the main headlight should have a large black rubber cover that seals around the base of the main bulb.
Old 09-02-2011, 06:00 AM   #8
Old 09-02-2011, 06:38 PM   #9
BennyLava
Dang. How'd you know it was me? You know benny lava drives a yaris over there in india.
But so from what I gather from this thread, this whole process is a huge pain in the rump.
Old 09-02-2011, 09:09 AM   #10
AppleJacks716
Drives: 2010 5 Door
Yep run a bead of silicone on the outside along the joint. No need to pull it apart unless you are painting it.
Old 09-02-2011, 09:47 PM   #11
OTA'sTOY
DAT'S RIGHT I GOTz 2
OTA'sTOY's Avatar
Drives: '10 5dr
best bet it leaking through the headlight adjuster mechanism just dry out the headlight then apply a bead of silicone around the adjuster
happened on my ford escape(RIP) found out after i drilled 1/8" holes along the bottom of headlight to drain it
OTA'sTOY is offline   Reply With Quote
Old 09-03-2011, 04:20 PM   #12
MickZEL
MickZEL's Avatar
Drives: Yaris sedan
Pour the lights in alcohol 96%.
Alcohol will use the rest of the moisture .
I like very much travel
MickZEL is offline   Reply With Quote
Old 09-04-2011, 12:07 AM   #13
BennyLava
Yeah I guess I'll just go through all the trouble and take the whole headlight out of there. Anyone ever done that? How hard was it?
Old 09-04-2011, 12:59 AM   #14
Bluevitz-rs
Bluevitz-rs's Avatar
Drives: '05 6-Spd Vitz RS
are you out of warranty already?
Sound when making a left turn (a water flow sound) jimmydie DIY / Maintenance / Service 9 06-20-2013 06:35 PM
DIY Projector/HID (sedan) Brian DIY / Maintenance / Service 145 02-05-2012 05:13 AM
How To Smoked Sedan Headlight -DIY zulhizainL902S DIY / Maintenance / Service 26 01-14-2011 03:12 AM
07' HB Water Accumulation in hatch bobolinko General Yaris / Vitz Discussion 9 09-26-2010 03:55 AM
Glassylite Headlight Restoration Kit TEHxFALLEN V1.2 Photo-Video-Media Gallery 1 07-03-2010 01:51 AM
