Old 08-12-2011, 08:00 PM   #1
bronsin
bronsin's Avatar
How Long Till It Blows?
Rutt Row.
26 months and 26k miles old.
Did anyone get this but not have a total failure for a while?
Coolant level is now and has always been "FULL"
Cant see anything around the water pump.
Old 08-12-2011, 08:04 PM   #2
TEHxFALLEN V1.2
TEHxFALLEN V1.2's Avatar
Drives: '08 Lexus IS-F
I hate waiting.
Sponsored by: Micro Image
http://microimageonline.com
Old 08-12-2011, 08:05 PM   #3
Klink10
Klink10's Avatar
Take a mirror and angle it down to where you can see the inside of the waterpump pulley, bet it's pink and crusty in there. You do have the tell tale sign on the hood however.
Old 08-12-2011, 09:31 PM   #4
bronsin
bronsin's Avatar
I felt inside the wp pulley butthere ws no crust there. Im wondering if this could be stable for a lobg time?
Or will it suddenly let loose?
Old 08-13-2011, 03:15 AM   #5
ilikerice
ilikerice's Avatar
Drives: 2010 black yaris
id go ahead and start saving up now if your going to take it to someone else. Or just buy the new water pump and get it over with now. Its obviously leaking.
Old 08-13-2011, 07:52 AM   #6
bronsin
bronsin's Avatar
As much as I cannot stand anyone else monkeying with my car its under warranty until next spring.
It seems though I have heard stories about new (Toyota) pumps failing too. Perhaps I should go with after market?
Also I work with engineers diagnosing complicated devices used in military and space appplications. (they design it I build it) So I am used to thiniking out of the box on things. Like: the splash looks old and there isnt a lot of it. Perhaps it just leaks a little once or twice and then it stops?
Thats why I want to ask others: is failure inevitable at this point?
Also I just drove 10,400 miles to Alsaka and back in 16 days. There were lots of days I was going 80 mph all day for 10 or 12 hours.
Maybe that has something to do with it?
Old 08-13-2011, 08:19 AM   #7
Klink10
Klink10's Avatar
My 07 HB let go at just under 15K the beginning of this year. I replaced myself with a Toyota pump from a online discounter. Did the thermostat and fluid change at the same time. I think the issue was part my fault in that I might have overtightened the belt adjustment after replacing my pulleys. I'd clear the issue up.
Old 08-13-2011, 08:41 AM   #8
bronsin
bronsin's Avatar
Now that I think about it in Fairbanks AK last month before leaving for home I changed the oil and checked the air filter in the Walmart parking lot there. I also checked the hood for tell tale water pump stains.
There werent any.
This has happened since then.
I know people have changed pulleys etc and the thought is perhaps this has something to do with the pump failing?
For the record I have no different pulleys and the belt has never been touched.
And in my (35 years of) experience Ive never seen a maladjusted belt cause a waterpump to leak.
My 2 cents.
Old 08-13-2011, 08:56 AM   #9
ROCKLANDTOYOTA
JOE GIRTH
Drives: YARIS 3DOOR
pump failure IS NOT caused by afteermarket pulley/s as i am testement to that with factory pump and 50K still going strong. Toyota has a problem with once again outsourcing parts and this water pump failure goes beyond just yaris models....
http://www.carid.com/toyota-accessories/
site has a FEW interesting yaris items.....
ROCKLANDTOYOTA is offline   Reply With Quote
Old 08-13-2011, 11:28 AM   #10
bronsin
bronsin's Avatar
I was thinking that. Toyota water pumps used to last 150k miles or at any rate more than American cars did (typically 50-60k) My Mercedes 240Ds pumps failed EVERY 60k miles almost to the mile.
Thats why I wanted to ask if the aftermarket pumps are lastsing longer? I guess Im going to have T replace it cause its under warranty.
Old 08-13-2011, 11:33 AM   #11
marcus
toyota
marcus's Avatar
Drives: 2007 Yaris RS Blazed
covered by warranty 5 years/100k km...just had mine done by toyota leaked after 80k
Old 08-13-2011, 11:45 AM   #12
Klink10
Klink10's Avatar
I hope that my statement ref pulleys brought this on. My only thing was to point out that because I put them on and maybe overtightened the belt that I may have contributed to the failure so therefore I repaired myself. All is well.
Old 08-13-2011, 12:07 PM   #13
bronsin
bronsin's Avatar
Awesome!
Now...two questions.
If it fails OUT OF WarrANATY, how long is the repair covered for?
I assume if its warrantied for 100k miles they fix it free no mstter how many times it fails?
Old 08-13-2011, 12:51 PM   #14
ROCKLANDTOYOTA
JOE GIRTH
Drives: YARIS 3DOOR
which is why i made my statement of aftermarket parts not being a contributing factor....
Old 08-13-2011, 01:31 PM   #15
HTM Yaris
resident senior
HTM Yaris's Avatar
Drives: 07 Yaris
Maybe some road chemical that somehow got onto your belt and was slung upwards
Did you check your AC ?
Old 08-13-2011, 02:01 PM   #16
OTA'sTOY
DAT'S RIGHT I GOTz 2
OTA'sTOY's Avatar
Drives: '10 5dr
Awesome!
just to clear it up water pump is covered under powertrain warranty
which is 5yr/80k mi or 60mo/100k km
if it fail while its still under warranty the dealer has to change it no matter how many times it fails unless they find something that would cause it to fail prematurely
which they would have to prove it
if you change it through the dealer after warranty parts and labor should be covered by at least 12mo/12k mi
the main problem why alot of newer car parts fail in due to the higher use of recycled material
OTA'sTOY is offline   Reply With Quote
Old 08-13-2011, 02:07 PM   #17
ROCKLANDTOYOTA
JOE GIRTH
Drives: YARIS 3DOOR
not sure in the 50th state but in the 49 other's its 5 YEARS/ 60K for POWERTRAIN WARRANTY....
Old 08-13-2011, 02:09 PM   #18
OTA'sTOY
OTA'sTOY's Avatar
Drives: '10 5dr
true 5yr/60k mi my bad
LED'n it out (warning...big pics) custom Lftback Photo-Video-Media Gallery 9 05-24-2010 03:41 AM
Yaris - do you find it comfortable on long trips? 360cubes General Yaris / Vitz Discussion 51 05-04-2009 01:31 AM
Golfers: Long, Long Par 3! Benggolf2 Off-topic / Other Cars / Everything else Discussions 2 04-04-2009 04:57 AM
How long? Japan --> US KittenRD New YARIS Purchase Forum 4 05-30-2007 08:13 AM
