Old 09-12-2011, 04:55 PM   #1
be_ha
Drives: Yaris Hatch
Coolant Flush
Hey All,
I'm wanting to do a coolant flush on my 07 yaris LB (just under 110 k but would rather do it now vs the winter). I've done a bit of searching and would love some clarification if at all possible.
From what I gather there are a couple different places under the hood that need to be drained:
1. The radiator (drain at bottom)
2. The overflow tank
3. The block via the valve on the backside of the engine
I still haven't looked for number 3 yet does anyone have an idea where exactly this is?
yaris-me also posted this
"You don't have to drain the block. Warm the engine, then open the drain plug on the bottom of the radiator. When the flow slows, close drain and with the engine running, fill the radiator with water. Run the engine till it warms up and drain the water. Repeat two more times then let as much water drain out. Use undiluted antifreeze and add half of cooling liquid capacity. Run engine and fill with water till full."
this sounds quite easy would I get a complete flush with this?
Any extra info would be greatly appreciated!
Cheers,
B
be_ha is offline   Reply With Quote
Old 09-13-2011, 07:17 AM   #2
Klink10
Klink10's Avatar
The one on the block is at the backside about half way up or down. Looks like a spigot. To access you will have to lift the car. While folks have done this various different ways I was reluctant to introduce anything but the "pink stuff" in mine. Hose water is not on my list of suitable fluids for the cooling system. Even draining all those listed you will not get all the fluid. There will be a pocket retained in the area behind the water pump and thermostat. I found this out after draining to replace my waterpump.
Old 09-14-2011, 08:12 PM   #3
ecc_33
ecc_33's Avatar
Drives: 2008 toyota yaris
drain and flush good enough
08 toyota yaris with some big tires lol
02 chevy duramax that runs 11.63 at 116 mph in the 1/4 mile
ecc_33 is offline   Reply With Quote
Old 09-15-2011, 12:11 PM   #4
Vinceb
Drives: 2008 5 Speed Sedan
I asked Toyota about changing the fluid for me and they said that Toyota Canada rec amends only drain and fill, not to flush it with any kind of pressure. i'm just going to drain mine from the rad, reservoir and I doubt i'll go for the block
Vinceb is offline   Reply With Quote
Old 09-15-2011, 12:15 PM   #5
Klink10
Klink10's Avatar
That's cool. Remember to take your reading to ensure you have the protection for your area. I know it gets cold in Canada.
Coolant Service N9QGS DIY / Maintenance / Service 31 11-27-2012 07:55 AM
Alternatives to Toyota "pink" super long life coolant Camberix DIY / Maintenance / Service 10 03-30-2011 12:42 PM
coolant reservoir? toad DIY / Maintenance / Service 10 11-02-2010 12:02 PM
coolant flush/ water pump jstantherprsn DIY / Maintenance / Service 26 10-26-2010 11:36 AM
Check your coolant bottle UTVitz DIY / Maintenance / Service 13 12-16-2009 10:13 PM
