![]() Drives: Yaris 2007 Join Date: Aug 2011
Yaris 2007 remote entry doesn't open (it only closes)
Hello everyone, I'm experiencing a strange issue with my Yaris 2007 remote entry control; maybe someone could share some light on it.
Sorry for my bad "technical" english (hope I'm using the right terms). The issue is this: on the remote entry control only the Lock button works, Unlock does nothing. Details:
Tests I've done:
I tried to re-add the remote following the procedure here (http://www.yarisworld.com/forums/showthread.php?t=20865), but nothing changed. To confirm I followed the steps correctly I also tried to remove all registered remotes; after that the remote was fully nonfunctional. Then I re-added it, but I still have the same issue: Lock button works but Unlock not (LED key lights up with both buttons). Hope someone could help me, I'm getting crazy
![]() ![]() ![]() Drives: 2009 3dr LB Manual Join Date: Mar 2010
Well, before you go too crazy, and before other people post, maybe try cleaning the buttons first? I know you said the light comes on, but that doesn't mean anything. I'd say pop the remote apart and clean the contacts just to be safe. It wouldn't hurt, and will only take a few minutes. Plus it's probably dirty after all these years.
![]() ![]() ![]() ![]() Drives: 2009 Meteorite Metallic LB MT Join Date: Oct 2008
I would add that even though the LED lights, doesn't necessarily mean that the battery
is still good. As suggested, why not take it apart and clean it. Check the battery voltage or even replace it. That way, you know you are probably starting with a like new remote. CTScott can verify, but LEDs only need about 0.7v to light. I believe the battery in the remote is a 3.0v. So, if it is indeed the original battery from 2007, it might be time to change it anyway. |
#4 | |
Thank you both for your replies
I'll try ASAP, but I don't think this could be a solution. Button should be a single contact one, so if the LED lights up it means the contact is closed... But maybe the button is a double contact, one for the power/LED and the other for the command; I'll check it this evening. Quote:
Lock ALWAYS works, even far from the car, no one single command missed. Unlock NEVER works, even near to the car. That's why I excluded a battery issue. Anyway it worths a try... |
With the way that the remotes work, the lights wouldn't light up unless the microcontroller saw the switch input, so I don't think it's a contact issue, and since it works for lock, I don't think it is battery either.
The "Door Control Receiver" receives the wireless signal from the remote and then sends the lock or unlock command to the "Main Body ECU" via LIN Bus. So, the main body ECU is the one who should be doing the work. The switch on the door is an input to the Main Body ECU, so since it works with the switch, it seems that the main body ECU is OK. So, without either connecting the Toyota TechStream system to the car to diagnose if the command from the remote is coming through, or having some parts to swap (a remote and a Door Control Receiver) it is difficult to determine where the problem is.
I've made a little step forward.
I measured the cell battery: 2.9v (ok, with no charge attached, anyway...) I tried cleaning the button with contact cleaner: no way. Then a lucky break: pressing the Unlock button twice really quick it worked, all of the times. When I say really quick I mean really quick, say 2 presses in less than 0.3 seconds. It seems some kind of security feature
#7 | |
#8 | |
Well, I used a spray cleaner (the one used in my electronic lab to deoxidate contacts), and I tried to put it deeply into the button. Another thing that makes me think about a "software" issue is the following test. I tried alternating a double-quick press to a single press, in a sequence like this: XX--(3s pause)--X----XX----X----XX----X---- and so on. The double clicks were all successful and all the single ones failed. AFAIK a bad-contact issue should not be so regular, I expected that some of the single presses was successful, and/or some of the double ones fail. I'll try to remove the remote battery and leave it unpowered for some time, then delete and re-register it. Who knows? |
| Tags |
| remote entry |
| News : 2007 Toyota Yaris - the little Euro's official arrival | VitzBoy | General Yaris / Vitz Discussion | 9 | 06-06-2017 12:51 AM |
| 2007 Yaris hatchback pre-wired for Cruise control? | naeemishaq | General Yaris / Vitz Discussion | 5 | 11-15-2010 10:31 AM |
