Old 01-18-2007, 02:34 PM   #1
CASTREX
Who said Yaris was slow?
CASTREX's Avatar
Drives: Yaris T-Sport 2008
Shocks upgrade???
I wonder?? Besides the expensive TRD shocks, is there any other option to upgrade OEM shocks when you're riding lowering springs? Tanabe DF's in my case.
Thanks for the info!
Old 01-18-2007, 07:42 PM   #2
Galavoxx
Galavoxx's Avatar
Drives: Yaris Hatch
From what I've been told and seen, there isn't a thing. Later this year, there will be many options.
Galavoxx is offline   Reply With Quote
Old 01-18-2007, 08:07 PM   #3
Biggie™
Biggie™'s Avatar
Drives: '07 3 Door Yaris of Doom!
Cusco, Tein and HKS all make suspension for the Yaris!
Biggie™ is offline   Reply With Quote
Old 01-18-2007, 09:12 PM   #4
Galavoxx
Galavoxx's Avatar
Drives: Yaris Hatch
Aren't those all coil-over sets. I think Catrex is just looking for absorbers.
Old 01-18-2007, 09:52 PM   #5
dngz
dngz's Avatar
Drives: black yaris sedan
Tein only makes the Tein Basics for the yaris. Cant adjust stiffness, only the height. So their EDFC wont work on our car.. But its still not too bad.. the coilovers are already pretty stiff.. if ur looking for stiffness that is..
dngz is offline   Reply With Quote
Old 01-18-2007, 11:40 PM   #6
Galavoxx
Galavoxx's Avatar
Drives: Yaris Hatch
I'm not good with abbreviations...what is "EDFC"?
Old 01-18-2007, 11:45 PM   #7
largeorangefont
Break'em off some.
largeorangefont's Avatar
Drives: 07 Yaris LB, 04 Cobra
Its the TEIN servos that you attach to the strut tops to adjust dampening on the fly with the dash mounted controller.
Old 01-18-2007, 11:59 PM   #8
Galavoxx
Galavoxx's Avatar
Drives: Yaris Hatch
Ahhhh yesss... those sweet little thingys. I believe eTimago has some on his car.
Old 01-19-2007, 12:12 AM   #9
largeorangefont
Break'em off some.
How is your car with the TRD struts? I think I'm gonna run those springtechs like you instead of the Tanabe DFs.
Old 01-19-2007, 02:03 AM   #10
dngz
dngz's Avatar
umm.. just thinking about this but... shouldnt this be in the wheels/tires/suspension forum?
Old 01-19-2007, 02:24 AM   #11
CASTREX
CASTREX's Avatar
Yes, I´m just thinking about the shock absorbers. I alredy have the tanabe DFs springs and don´t want to expend big bucks on coilover systems...
... It probably should.
Old 01-22-2007, 03:41 PM   #12
St_G
Drives: Black 2007 Yaris Liftback 1.5
$330 is just for the shocks at that site, if I'm reading it right.
St_G is offline   Reply With Quote
Old 01-22-2007, 03:56 PM   #13
Galavoxx
Galavoxx's Avatar
Drives: Yaris Hatch
My apologies. I swear they were advertising the combo for $330 just last week.
Either way, I still stand by my statement. When considering just the lowering springs, think about those weak little stockie shocks. The dampening just isn't agressive enough to handle the decreased suspension travel. There should be some other stand alone absorbers on the market soon. Hopefully the prices will come down.
Old 01-27-2007, 12:28 PM   #14
Nimble
Modification Condoner.
Drives: 2007 Black Sand Liftback
I have a question about the compoisition of the stock vs TRD shocks.
Are our stock shocks/struts gas or oil filled? I'm guessing either oil or twin tube gas at best. Are the TRD's at least twin tube gas, hopefully montube gas?
Nimble is offline   Reply With Quote
Old 01-27-2007, 01:05 PM   #15
Galavoxx
Galavoxx's Avatar
Drives: Yaris Hatch
Both stock and TRD are gas/oil filled. The TRDs have nitrogen gas, probably at a higher pressure with a heavier weight oil. They are likely rebranded Gas-a-Just. Both the TRD and the OEM are made by KYB. Here is a blurb I just found:
These KYB Gas-a-Just shocks use higher gas pressure to keep your tires glued to the road. The KYB Gas-a-Just shocks' velocity-sensitive valving system adjusts quickly to changing road conditions for maximum comfort in any situation. Their monotube configuration eliminates aeration and foaming, their micro-smooth, hard-chromed pistons extend their life, and their seamless cylinders and eyerings completely eliminate seam failures.
Old 01-27-2007, 01:22 PM   #16
Nimble
Exactly the info I wanted to see. You are a big help, thanks. That helps me feel better about just lowering my car with stock shocks/struts with the Tanabe DF's I have on order. I know they will ruin my stock stuff within 30K tops, but that's ok for me now. Once they go, hopefully some GOOD shocks like Koni/Bilstein are available, not crap like KYB or TRD.
Old 01-27-2007, 01:59 PM   #17
Galavoxx
Galavoxx's Avatar
Drives: Yaris Hatch
I wanted Konis or Blistein but couldn't wait. After I lowered the car, it was apparent I needed some stiffer shocks. The TRDs work well but could be just a hair more aggressive to suite my taste. Either way, they are a huge improvement over stock. Adjustable dampening would be ideal.
Old 01-28-2007, 02:13 PM   #18
CASTREX
CASTREX's Avatar
So we can get an upgrade to the OEM shocks without paying the extra $$$ for the TRD logo. That's what I wanted to know!
Now, anoyone has any info on what would be the KYB equivalent to the TRD option?
Any one with TRD shocks that can provide the specs, p/n etc... to help find the KYB match.
Also, about KYB. It might not be the best shock performance wise, but I can tell you those are some long lasting and good quality shocks.
Teh Power Upgrade YarisKid DIY / Maintenance / Service 9 01-22-2007 02:56 PM
Shocks and springs Q grimez Wheels, Tires and Suspension Forum sponsored by The Tire Rack 3 10-19-2006 09:48 AM
uk yaris stereo upgrade yaris781 In Car Entertainment + Electronics (audio / video / alarm) 5 09-05-2006 06:30 PM
TRD lowering springs' and/or shocks' Ride Quality?? static808 Wheels, Tires and Suspension Forum sponsored by The Tire Rack 28 08-29-2006 01:42 PM
Security upgrade Ryu General Yaris / Vitz Discussion 7 05-09-2006 10:00 PM
