Local Sh*t Disturber
Drives: 2009 Yaris LB Join Date: Aug 2009
Throttle Body spacer?
Will our throttle bodies bolt to a 1nzfe XA/XB throttle body spacer?
You think your Yaris is low and fitted LOLzzzzz |
2ZR swap. DO IT! Ask how!
I don't think they use the same bolt pattern. From what I can find on google, it appears that the yaris has a 4-bolt pattern and the xB uses a 3-bolt pattern. Take a look at this one from a Matrix that bolts on to the yaris directly vs one from an xB that is compatible with the 1ZZ engine. As far as I can tell, the xB is a first gen, 1nz-fe engine. The difference is the intake header, which is where the TB mounts up.
If you're looking to get one for the yaris, try looking at the corolla as well: http://www.amazon.com/Street-Perform...7780717&sr=1-1 Last edited by CrankyOldMan; 10-04-2011 at 10:12 PM. |
Thank you!
| 1ZZ Throttle Body Spacer | tk-421 | Performance Modifications | 34 | 07-11-2017 09:48 PM |
| FS- 1ZZ Throttle Body, Spacer, NST SSK | MGargano | Items for Sale by private party | 9 | 09-01-2010 08:48 PM |
| Throttle Body Spacer?? | ozmdd | Performance Modifications | 11 | 09-30-2009 10:57 AM |
| For Sale: 1ZZ Throttle Body and 0.25" aluminum wheel spacers | m911gt | Items for Sale by private party | 6 | 04-25-2009 08:52 PM |
| Toyota Throttle Body Spacer: the Best Fuel-Saving Device | davidmills | Performance Modifications | 1 | 07-01-2007 11:38 PM |
