Old 01-07-2013, 09:45 AM   #1
narly charley
Drives: 2010 Yaris "L" 5 Speed
Talking Post your oil change regimen!
As the title says... Post what brand, weight, and mileage intervals you do your oil changes with. Also, don't be afraid to throw in your oil filter brand that you like.
I use Pennzoil Ultra. 5W-30. I change at every 5,000 miles. I use Toyota OEM filters.
narly charley is offline   Reply With Quote
Old 01-07-2013, 11:33 AM   #2
UberSilver
UberSilver's Avatar
Mobil1 Extended performance 5/30 once per year, and Denso filter every 6 months.
http://www.mobiloil.com/USA-English/...nce_5W-30.aspx
http://www.densoaftermarket.com/oil-filter.php
Old 01-07-2013, 12:12 PM   #3
DebbyM46227
DebbyM46227's Avatar
Drives: 2017 Yaris IA, Pulse Red, Auto
So far, mine were through ToyotaCare that came with my car. Whatever synthetic oil they use. The next oil change I have to pay for. I may go to Car-X.
DebbyM46227 is offline   Reply With Quote
Old 01-07-2013, 01:11 PM   #4
mryaris
Drives: 2010 Carmine Red hatchback
I have used Mobil 1 0W-30 & NAPA gold filters since my Yaris was new. It has 67K miles on it now and I change the oil every 5000 miles, although I plan on extending it to 10000 miles next oil change (I will switch to NAPA platinum filter).
mryaris is offline   Reply With Quote
Old 01-07-2013, 01:32 PM   #5
mr_miles
Drives: 2013 Yaris
I'm on Toyota care right now also, but as soon as I'm off it, mobil one synthetic 5w30 with matching filter. (always buy it on sale, 28.99 for the whole thing!)
Old 01-07-2013, 01:38 PM   #6
narly charley
Why would you guys EVER go 10,000 miles on an oil change? That is just crazy.
Old 01-07-2013, 03:17 PM   #7
UberSilver
UberSilver's Avatar
I changed the oil every 2 years (18k~20k miles)on my 85 PU(22r engine), for 17 years. I put close to 500K miles on that truck, and drove it to the junk yard.
Never had any issues with the truck or engine.
Toyotas do not need 3k~5k mile oil changes. It's just a waste of money.(IMO).
Old 01-15-2013, 05:12 AM   #8
nookandcrannycar
^^^^^This. Pretty much. For the last 122k + miles I've tried to be just under 20k miles between oil/filter changes. Over the 'life' of my Yaris, per my log book, I've changed my oil and filter at the following mileage points on the car: 10,002 miles.....15,119 miles.....20,003 miles.....25,057 miles.....38,036 miles.....72,050 miles.....87,708 miles.....110,150 miles.....113,548 miles.....131,751 miles.....153,918 miles.....169,891 miles.....188,622 miles.....207,297 miles.....226,835 miles. I currently have 235,728 miles on my Yaris. I had the spark plugs replaced at just over 208,000 miles for the first time (amazingly, a Toyota dealer was the cheapest place I found). When I picked the car up, the service writer at the dealership told me they tried to find things to recommend that I do re service, and the only thing they could come up with was to change the air filter (I had a new one waiting in the wings t put in myself after the spark plug change). He said the engine is in great shape and is not burning any oil.
P.S. oops...almost certain I left one out. I felt guilty after the 34,014 lapse between odometer 38,036 and 72,050 so I changed again at 74,000+ . Will check log book again.
P.P.S. Checked. 74,000+, to be exact, was 74,480
Old 01-15-2013, 10:01 AM   #9
UberSilver
UberSilver's Avatar
Good to hear! FYI, I will be changing the auto trans fluid once a year as well, as it only needs 3 quarts, and I pretty much drive my cars like I've stolen them
Old 01-07-2013, 02:47 PM   #10
I change mine once a year with Amsoil. I bounce from 0w-20 and 5w-20. I'm also using Amsoil EA oil filters, once a year as well. When Amsoil temporarily discontinued their EA oil filter for the Yaris, I was using MANN oil filters and changing them every 7500 miles.
Old 01-07-2013, 05:10 PM   #11
toad
toad's Avatar
Drives: street-legal go-kart
i change mine every 10k with pennzoil platinum 5w-30 and mobil 1 extended performance filters. been using this combination since the car was brand new and with nearly 150k miles i've had no problems!
i'm not telling anyone else what to do- just what works for me.
toad is offline   Reply With Quote
Old 01-07-2013, 05:23 PM   #12
MadMax
MadMax's Avatar
What? We have to change the oil in our cars?!?
Old 01-07-2013, 06:29 PM   #13
narly charley
You guys are crazy... Haha!
Old 01-07-2013, 06:39 PM   #14
mr_miles
Drives: 2013 Yaris
Most full synthetic oils suggest changing oil every 10k. i run 8 at the most, but if I plan on going over 5k, i'll change the filter and top it off.
Old 01-07-2013, 06:52 PM   #15
Been doing this for a while now, and my engine compression test is just a few psi lower than a brand new engine. So I think the Amsoil is worth it ;)
Old 01-07-2013, 11:12 PM   #16
Hershey
Twice a year at 6 months or just under 5,000 miles . Have to because of the Platinum warranty . Use Shell synthetic 5w-20 for the cold months and their 5w-30 during the warmer weather . Now using AC Delco PF 1233 oil filter for less than $4 each . Shell synthetic is under $3.40 a quart . May get a used oil analysis at upcoming oil change . Depends if the weather cooperates . Outdoor O.C. on the drive .
Old 01-08-2013, 12:46 AM   #17
UberSilver
UberSilver's Avatar
You'd be better off running 0/30 for cold and 5/30 for hot.
The 30 wt end of the oil is measured at 212*F, that does not change once your engine is warmed up, wether it be winter or summer.
Old 01-08-2013, 02:37 AM   #18
Yaristeve
Drives: 3-door hatch
Castrol GTX, 5W-30, OEM filter every 3,000 miles. I buy my filters on ebay by the case.
Oil filter seeping oil from seal : Should I change it ? Hershey DIY / Maintenance / Service 33 11-14-2012 04:25 PM
TGMO OW20 Oil Change ChilliwackGuy DIY / Maintenance / Service 23 10-24-2010 01:10 AM
Dealer oil change boggydee DIY / Maintenance / Service 16 06-30-2010 11:21 PM
Oil change time intervals PaidTimeOff DIY / Maintenance / Service 17 01-29-2009 07:14 PM
Oil change question Ryu DIY / Maintenance / Service 22 03-07-2006 11:21 PM
