Thinking about a putting TPMS in a winter wheels setup. After looking at the EWD for both the Yaris and xD, it seems the xD module has an extra wire unused by the Yaris. Plugs look physically compatible.
So, anyone with access to an xD kind enough to test out whether or not: 1. the xD module will connect and 2. once connected, will it work? Yes, it's a lot of trouble but my local junkyards have xDs but no yaris TPMS ECUs.. |
I know the XD has a reset button under the driver's side dash...that might be what that wire is for...
The XD's TPWS receiver and ECU both have different part numbers than the Yaris ones, so I don't believe that the XD parts are swappable.
| DIY - Bypassing Tire Pressure Warning System (TPWS / TPMS) | CTScott | DIY / Maintenance / Service | 221 | 07-16-2025 01:20 AM |
| DIY - - -TPMS work around | rningonfumes | DIY / Maintenance / Service | 6 | 03-03-2011 08:11 PM |
| Yaris ECU broken??!!!!!! | phb10186 | General Yaris / Vitz Discussion | 30 | 05-26-2010 09:56 AM |
| tpms compatibility? | bwong2 | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 8 | 07-11-2009 09:33 AM |
| Tricking the ECU to Relearn AF map | gwasabi | Performance Modifications | 126 | 05-16-2009 06:15 PM |
