Old 12-05-2011, 01:45 AM   #1
YAR1S
YAR1S's Avatar
14" rims... will these work?
http://nashville.craigslist.org/pts/2712296108.html
I am looking at these as a new alternative to my current wheels... they are 14" 4x100. 120$. Dunno about offset.
Plan on going to see them. Any opinions? experience with 14"s? how much do 14" tires cost approx?
-Jen <3
Old 12-05-2011, 04:01 AM   #2
14's will work with the Yaris. However, you might want to check the center bore size (if it's bigger than 54.1mm, that's fine since they make hubcentric rings, if it's smaller, it won't work). Offset, well, as long as it's not crazy low, it'll work. lol
Tires can be had for as little as $60 at your local America's Tire (or even cheaper if you get a generic brand at a tire shop).
Old 12-05-2011, 04:01 AM   #3
Personally, if I'm getting rims that small, they better be EXTREMELY light-weight. Really no point in getting smaller rims if they're heavy.
Old 12-05-2011, 08:20 AM   #4
33OH
Drives: '08 Yaris
14's will work fine, I've ran 2 sets. The offset doesn't go by the rim height, just the wideness + offset numbers. Those look like they'll work fine, most 14's aren't as wide as 15's and up. Just make sure they're not 14x8 or 14x9 or anything crazy.
As for tires... CHEAP.
Old 12-05-2011, 08:36 AM   #5
Offset makes the biggest difference on the harks to clear calipers. For instance, my 14x5 steelies fit great but 14" "Daisy" alloys from a miata rub the calipers
Old 12-05-2011, 09:31 AM   #6
33OH
Drives: '08 Yaris
^ True for OEM 14's, but for the aftermarket ones in question, they will clear the calipers easy.
Old 12-05-2011, 12:01 PM   #7
I see the pic of them now....they'll likely work
To the OP: 14" tires are nice and cheap, but tire options are limited. Regardless off the tire you're going to have a ton of sidewall and tire flex. In my signature I have 14" r-888's on the car and I could feel the tires squishing as I cornered at the auto-x
CL find 14" rims maybe kosei k1 ts $250 (brooklyn) sex NY / NJ/ CT / PA 0 01-11-2011 12:36 PM
What are you doing right now? Bob_VT Off-topic / Other Cars / Everything else Discussions 26819 12-31-2010 10:48 AM
Anyone actually get the 14" rims? WolfWings Wheels, Tires and Suspension Forum sponsored by The Tire Rack 7 09-10-2007 09:43 PM
Need help when ordering my tires and rims thomasward00 Wheels, Tires and Suspension Forum sponsored by The Tire Rack 4 04-26-2007 09:40 PM
hufeisen rims JustYYaris Wheels, Tires and Suspension Forum sponsored by The Tire Rack 4 01-17-2007 03:16 PM
