cusco coilovers installed
alright guys i just finished the install yesterday
thanks john at bulletproof for hooking it up with the cuscos the total time for the whole install took me about 2 hours. ok lets start with the rear cause that is the easiest i was able to have access to a lift and power tools so it made things a lot quicker. these are the tools i used 20mm for the lug nuts 14mm for the rear strut nut 14mm for the inside rear strut nut ![]() so the first thing i did was pop of the plastic cover in the inside of the car then loosen the 14mm thats holding the strut to the car ![]() then i lifted up the car and the springs fell off and the strut came out also ![]() ![]() this is wat the stock ones look like compared to the cusco ![]() go ahead and transfer over the plastic shield for the rear strut to the cuscos so they look like this ![]() i wasnt sure wat side the spring goes but i figured the adjusters went below but others say they go on top transfer over the rubbers from top to bottom on the spring ![]() stick the strut on and hand tighten the 14mm for the strut for now and put the spring onto the subframe use a jack and jack up the subframe ![]() align everything and get the spring to line up and the strut to enter the car with no problem ![]() tighten all the bolts and the rear is done this is wat is should look like when its done i didnt slam the rear all the way ![]() now to the fronts ![]() push in the plastic clips there are 3 one right one left and one in the middle ![]() next pull the panels out making sure nothing is caught onto it ![]() disconnect the windshield washer fluid from the left and the rest of thepanels should come out looking like this ![]() pop off the wiper covers and take the nuts out using a 14mm wiggle it out and they should come out ![]() then the rest ofthe panels should come out ![]() take the rubber boot off the top ![]() i was lucky to have this tool an angled wrench 17 and a allen to take the front struts out with not too much of a problem because theres not a lot of room to work with and people always cut there hands. ![]() loosen the top nut and now at the bottom take the 2 19mm nuts off holding the strut to the spindle ,take the sway bar link off using a 17mm, and take off the 14mm bolt holding the brake line on. ![]() i used a bungy cored to hold on the to brake rotor from dangaling around but after u take out the strut it looks empty like this ![]() some use a spring compressor to take out the spring because we are going to have to use the top mounts for they are not given. what i did was put the strut on the ground have a friend stand on it and i used my impact to take it out applying pressure and bam it comes right out dont be scared it wasnt too bad. ![]() i didnt reused the bump stopper and the boot cause cusco already provides those. ![]() next i put the strut in and pushed up on the strut and tightend the 17mm on top by hand till i couldnt any more. ![]() then i reinstalled the bolt and nut for the shock and the sway bar link and the brake line. ![]() to make things easier i used a jack to push up on this assembly to line up with the shock ![]() tighten everything and then the top nut comes which took me like 5 minutes to tighten with not a lot of room to work with ![]() i put all the panels back and double checked my work ![]() lowered the car and slammed the fronts all the way ![]() the install is finally complete here are some pics of my car hope you guys enjoyed it ![]() ![]()
niiice!!! but... i think ur vitz is on the wrong side ><!!
![]() ![]() ![]() ![]() Drives: 240sx, 00 Celica Join Date: Apr 2006
so it fits nicely then...
SUPPORT YARISWORLD'S VERY FIRST SPONSOR!!
C2 AUTOMOTIVE SPECIAL 24711 Redlands Blvd., Ste. I Loma Linda, CA 92354 T: 909-796-8189 E-mail: info@c2auto.com AIM: wide180sx |
好多人&
Drives: . Join Date: Feb 2006
Interesting you didn't take out the whole wiper assembly to get access to the top hat nut. I didn't use a wrench to get at the top nut though.. I'll remember that when I take the gear off the car.
![]() ![]() ![]() ![]() ![]() Drives: icebox Join Date: Apr 2006
Looks good...
It is stunning!!!
![]() ![]() Drives: MK I Vitz 1.0l F Package Join Date: Jun 2006
Steel wheels must die!!
Looks good otherwise dude |
Ηave you tested it on the road?
Love the look... Im sure your car must track awesome with all the suspension mods you have done.. has it been to the track yet?
no it hasnt been to the track yet but i will soon the car drives great i can take turns in 3rd gear going about 40mph but what i noticed is what i really need is an lsd ill wait till i need a clutch and do short gears and a lsd
好多人&
Stick with the 15" ... they do make the car much faster off the line with less weight to turn than 16". Anyway, the tyres will be cheap in 15" so keep burning them. :) I do.. sometimes.
![]() ![]() ![]() Drives: 00 itr Join Date: May 2006
great writeup Ken, they look great on your car...glad i could help supply these to you. car looks very nice, we'll get some wheels on soon ;)
Very nice! I'm jealous
You may want to pick up the max negative camber bolts from Toyota before taking it in for alignment... The 12.4mm ones are the smallest and should get you at least -1.2 deg. if not more
![]() ![]() Drives: Yaris Join Date: Jul 2006
I am very jealous too
just some information for everyone on what i feel are the most important specs to compare when suspension shopping. if you don't like to read, see the cliff notes at the end.
cusco compact s spring rates F:7k R:3.3k Non adjustable dampening ~$1200 HKS S-Compact Spring Rates F:5k R:8k 30 way adjustable dampening ~$1900 Tein Basic F:4k R:3.1k Non adjustable dampening. ~$950.00 As you can see the spring rates are very soft for the basics, cusco and hks are much more aggresive with their rates and the valving to go with it. In terms of comparing what is the best setup to get, I believe the Tein does not offer anything outside of height adjustability since the spring rates are no stiffer then what is found from Tanabe's springs, of which there will be a GF210 coming out with ~4k rates(it's out in Japan, it'll be out here). The cusco is your best performance related upgrade since the Tein would be purely cosmetic. For those that want something more trackable, the HKS would be your solution with the ability to fine tune your dampening for different course and driving situations. Of course at this time the HKS are not readily available in the states, I don't see HKS USA bringing this product over anytime soon as stockable inventory so you'll need to wait for it. The cusco and tein products will be stocked stateside, it just may take some time for the suppliers to gauge the correct inventory levels so expect backordered product in the beginning. Cliff Notes: Cusco compact S is probably best value at the moment. HKS is tops for track use. Tein Basic is purely cosmetic. |
1 set will be arriving end of october, if you'd like it i recommend ordering it now.
http://www.bulletproofautomotive.com...il.php?ID=5268 |
The LittleBastard
Drives: 2007 Yaris Liftback Join Date: Sep 2006
Wow Looks great. Sure it rides nice also, but must be stiff ride.
John I would have thought teins would be adjustable also, surprised to see they aren't. So it's a basic coilover with no shock adjustments, and low spring rates? I'm not looking to upograde my yaris in performence, so maybe just a cosmetic upgrade would be better for me.
Yaris Mods: 20% Tints Ground wires 2007 Toyota Yaris Liftback - Current 2004 Honda S2000 - Sold 1986 Toyota Corolla SR5 - Sold DIY: Groundwire Kit |
the only adjustable ones that i've seen are the hks. the cusco comp-s, zero-1, and tein basic are all non adjustable dampening.
the cusco has rather stiff rates compared to tein, i remember making a post somewhere around here regarding spring rates, i'll need to find it. |
| Cusco Comp-S Coilovers on their way!!! | BulletProofAuto | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 37 | 05-22-2007 01:45 PM |
| Comp S Coilovers for a discount and installed | BulletProofAuto | California | 1 | 05-12-2007 02:04 AM |
| Cusco Type 1 Lower Bar Installed [pics] | Chris07LB | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 23 | 10-19-2006 07:57 PM |
| has anyone installed a 3dr liftback lip spoiler? | DonnyRebel | DIY / Maintenance / Service | 10 | 09-14-2006 01:04 AM |
| cusco or c-one? | dngz | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 13 | 09-12-2006 08:53 PM |
