Old 08-09-2011, 11:32 PM   #1
hitmoninfinity
Drives: 07 Yaris Sedan
Help! I'm only getting 320 miles a tank!
I recently got new tires and wheels. The drop in mpg seems to have started around the same time. I'm not sure if that's the cause though. Both the tires and wheels are the same size as before. Does anyone know what the stock steelies weigh? My new rims weigh 17lbs each.
But now that I think about it, I think I was only getting 330-340 a tank before. I keep seeing all you guys in the 40 mpg range! I'm not a diehard mpg junkie, but I do drive pretty reasonably. Enough to be appalled when driving with anyone else. What can I do to get up towards 40 mpg?
Has anyone had to replace an O2 sensor yet? -Did it make a difference?
Is there any other maintenance issues I might be overlooking?
It's a 07 sedan with 50k on it.
hitmoninfinity is offline   Reply With Quote
Old 08-10-2011, 12:03 AM   #2
330miles is about right for in-city driving and not caring about economy so much
if you want 40mpg, you have to drive like a pussy
Old 08-10-2011, 01:07 AM   #3
digitalrain
Drives: 2011 yaris rs
I also found that getting new tires killed the MPG by about 3. Softer tread,even though it was the same size and all, made a big diff in the MPG. Got a quieter smoother ride with the new tires. Maybe bump up the tire pressure a bit?
320's not bad at all.
digitalrain is offline   Reply With Quote
Old 08-10-2011, 02:13 AM   #4
fnkngrv
Mr. 155 and climbing
fnkngrv's Avatar
Some people get 40 mpg however some people are also blowing some out their ass...just sayin.
Old 08-10-2011, 02:22 AM   #5
hitmoninfinity
I don't doubt that. But I still think I could be doing better.
Old 08-10-2011, 02:44 AM   #6
N9QGS
N9QGS's Avatar
Send a message via AIM to N9QGS Send a message via Yahoo to N9QGS
I have a 2007 Toyota Yaris S, if you keep lock the cruise control at under 3,000 (68 MPH) the car will do 40+ MPG all day. I have 185,300 on my car and still do 41 to 42 on my 60 miles work commutes on the interstate. Seriously planning to pick up a 2nd Yaris here before they change them up, hate the style of the new ones, Im learning about.
198K Miles
N9QGS is offline   Reply With Quote
Old 08-10-2011, 02:56 AM   #7
PETERPOOP
PETERPOOP's Avatar
Drives: 08 white liftback
That's average. If you want those higher numbers, you need to hyper mile.
Old 08-10-2011, 05:51 AM   #8
ilikerice
ilikerice's Avatar
Drives: 2010 black yaris
i aggree with ^ I get about 320 also, and I drive like a bat out of hell
Old 08-10-2011, 10:47 AM   #9
SilverBack
Joey
SilverBack's Avatar
Drives: '14 Scion xD 5-speed
Hmm, I'm a bit of a speeder and I still get at least 400 to the tank. Maybe it's got something to do with local climate?
Old 08-10-2011, 11:06 AM   #10
BEEF
BEEF's Avatar
Drives: 2008 yaris 3d
I don't know about the climate thing. I am in NC and I get 41mpg. I would think my climate isn't that different though I will admit that I drive it really easy.
Old 08-10-2011, 11:21 AM   #11
climate and driving style for sure... Hot weather here, and 99% city driving, gives me a maximum of 450km (280mi) per tank. The guys who get 40 MPG "without even trying" probably do a lot of slowish highway miles
Old 08-10-2011, 12:00 PM   #12
Lil Abner
Drives: 2009 3dr LB Manual
I get 41-42 mpg, but that's back roads, doing 55mph with the cruise on. When I do city driving, it drops down to low/mid 30's. So your 320 miles sounds about right. As mentioned, maybe add some more tire pressure?
Old 08-10-2011, 01:17 PM   #13
ATL_Want_A_Pabst
PBR!!!
Drives: 2011 Black Yaris 3 Door
http://geology.com/state-map/south-c...a.shtml#relief
Hills!!! <---- will affect gas mileage. And by the looks of it, you have plenty of them...
ATL_Want_A_Pabst is offline   Reply With Quote
Old 08-10-2011, 01:28 PM   #14
brg88tx
Drives: 07 Yaris Sedan, Auto
op, check the od (outside diameter) of your new tires and compare it to the od of the stock tires, 185/60r15. if your new od is larger it will show fewer miles than actual. the % difference can be found with online tire calculators.
brg88tx is offline   Reply With Quote
Old 08-10-2011, 01:36 PM   #15
malibuguy
Obsessed with 1.5L
Drives: '10 PW Yaris Sedan
i usually get just over 500 a tank...low 400s when i beat the hell out of the car, like the last tank (42.5mpg)
-Greg...the Exhaust Freak.
-82 Malibu, 1uzfe swap
-97 Tercel coupe, 1nzfe/4.31
-96 Tercel 4dr
Old 08-10-2011, 01:49 PM   #16
PETERPOOP
PETERPOOP's Avatar
NERD.
Old 08-10-2011, 05:24 PM   #17
OTA'sTOY
DAT'S RIGHT I GOTz 2
OTA'sTOY's Avatar
Drives: '10 5dr
service your car
OTA'sTOY is offline   Reply With Quote
Old 08-10-2011, 05:40 PM   #18
fnkngrv
fnkngrv's Avatar
I did get close to 40 boosted through the middle states on the way from Alabama to Maine. That was driving @ 10 over the limit. There are honestly too many variables to calculate for driving style, climate, and altitude. I know that I get better mileage here in Maine than in Alabama however there as stated are a BUNCH of variables. Once you get south of Virginia for example the highways/freeways are 70mph for the most part in my experience. Bottom line is Peter hit the nail on the head for the most part. I can tell you that prior to adding any mods, and I do mean any, I was always getting around 40mph highway cruising around 60-65 and still that when on I95 heading back and forth at roughly 70-75. Shrugs...if you want the best mileage you will need to find a good source for a gas station and hypermile like Peter suggested.
Help my yaris was doing 317 miler per tank now 265 miles pertank andres murcia Fuel Economy Forum 6 08-03-2010 06:27 PM
Miles per tank joeharth Fuel Economy Forum 61 07-08-2010 08:37 PM
Ford Fusion Hybrid does 1,445 miles on a tank captainm27 Fuel Economy Forum 25 08-05-2009 09:43 PM
Hypermiling the Toyota iQ: 500 miles per 8.5 gallon tank Thirty-Nine Off-topic / Other Cars / Everything else Discussions 8 02-03-2009 11:37 PM
How many miles are you getting on a tank? TDL General Yaris / Vitz Discussion 1 11-29-2006 05:28 PM
