![]() ![]() ![]() Drives: 2007 Yaris Hatchback Join Date: Jan 2010
belt slipping
Replaced serpentine belt 3 months ago and it is starting to slip at start-up. Especially wuth A/C turned on. I dont think I got belt tight enough when I replaced it as I was afraid of it being too tight and burning up water pump or alternator. I have 130k miles still origional water pump and alternator
Two Wheeled Fiend
Drives: 08 Yaris 2D Lftback 5-speed Join Date: Feb 2011
How much slack do you have? Did you accidentally get any grease or oil on the belt or pulley? Yeah you can over tighten belts but you really don't want room for slack. I always tighten mine until there is just enough tightness so there inst any slack. If it squeaks I'll tighten the bolt a 1/4 turn each time with the wrench until the belt stops slipping. However first step is to make sure the pulleys and belt are clean and free of oil and grease.
![]() 2008 Suzuki B-King 2001 Yamaha FZ1 (2005 motor swap) 1998 Suzuki Bandit 1200S 1983 Suzuki GR650 2008 Toyota Yaris 2DR HB (The Cage) |
![]() ![]() Drives: 2007 Toyota Yaris Sedan Join Date: Jun 2006
yeah sounds like you just need to tighten it a little.
![]() ![]() ![]() ![]() ![]() Drives: Scion FRS RS2, ‘21 Crosstrek Join Date: Oct 2008
Snug it up. It has likely just experienced some initial stretch which needs to be taken up.
TRD Upgrades: 18" Wheels wrapped in 215/35/18 PZero's, Sportivo Shocks/Struts, Lowering Springs, Swaybar, Axle-Back Exhaust, Oil Cap, Rad Cap, Signage. Aftermarket Goodies: Piggies SS, K&N Drop-In, Blitz S/C, DC Header, NST Pulley) Toyota Options/Accessories: Sport Pedal Covers, Sport Shift Knob, Ipod Interface, Summer Mats, Winter Mats, Cruise Control, Auto-Dim Mirror, Echo steelies with winter boots.
| Belt Tensioner for the Yaris | fmicle | DIY / Maintenance / Service | 25 | 11-27-2022 12:37 AM |
| Need new Serpentine/Auxilliary belt | ras3448 | DIY / Maintenance / Service | 21 | 07-16-2013 06:11 PM |
| Squealing Belt | rossman | DIY / Maintenance / Service | 8 | 01-31-2012 02:58 PM |
| squeaky belt | TickleTimeTim | DIY / Maintenance / Service | 14 | 03-17-2011 12:49 AM |
| The Accessory belt? | N9QGS | DIY / Maintenance / Service | 4 | 02-13-2009 12:05 AM |
