Old 02-01-2007, 02:17 PM   #1
marcus
toyota
marcus's Avatar
Drives: 2007 Yaris RS Blazed
really whats yaris 0-60 m/h
i cant seem to get the accurate answer..i know people drives the car differently but 0-60 or 0-100 km/h im curious on 1.5l 106 hp engine..
Old 02-01-2007, 07:14 PM   #2
marcus
toyota
marcus's Avatar
0-100 km/h ANYONE?????????????
Old 02-02-2007, 12:06 AM   #3
mikeukrainetz
mikeukrainetz's Avatar
Drives: 2006 Toyota Yaris
quick search netted these results:
Sedan S
http://autos.yahoo.com/toyota_yaris_s-performance/
European 1.0l Yaris HB
http://www.topgear.com/CarServlet?ev...de=E6&rCode=C7
Yaris LE HB - read through the driving impressions section
9.4s 0-60mph
http://www.canadiandriver.com/testdrives/06yaris2.htm
mikeukrainetz is offline   Reply With Quote
Old 02-02-2007, 12:07 AM   #4
swng
swng's Avatar
Drives: 06 3-dr auto RS
Some relevant information here:
http://en.autos.sympatico.msn.ca/Rev...umentid=635582
and here:
http://www.ajac.ca/english/files/Tes...rmanceData.pdf
swng is offline   Reply With Quote
Old 02-02-2007, 12:49 AM   #5
a little faster than a snail, a little slower than a turtle....
Old 02-02-2007, 01:47 AM   #6
dansides
dansides's Avatar
Drives: 07 3 dr
motor trend buyers guide 07 yaris 0-60 10.4 qtr 17.8 76.8 mp 07 fit 11.9 18.4 74.4 07 versa 9.7 17.4 78.6 all auto an yaris is a sdn
dansides is offline   Reply With Quote
Old 02-02-2007, 09:55 AM   #7
mcstarbucks
Drives: blazing blue 5sp HB
8.84 sec to 0-60 manual according to msn autos
mcstarbucks is offline   Reply With Quote
Old 02-02-2007, 12:22 PM   #8
mikeukrainetz
holy crap, all over the map on this...
Old 02-02-2007, 12:23 PM   #9
marcus
toyota
marcus's Avatar
thanks guys... although theres a big gap of about 2 seconds...average..wow..i guest im just gonna have to get it and find out..!!
Old 02-02-2007, 02:28 PM   #10
ChinoCharles
Drives: LB
My Yaris goes 0-60 in 4.6 seconds in REM sleep.
Old 02-02-2007, 03:56 PM   #11
CASTREX
Who said Yaris was slow?
CASTREX's Avatar
Drives: Yaris T-Sport 2008
I bet that in a free fall the Yaris could be just as fast as any other car!!
Old 02-02-2007, 04:05 PM   #12
hystria
hystria's Avatar
Drives: 2007 Orange Yaris Hb 3Drs
nope, it's lighter so it will fall slower
hystria is offline   Reply With Quote
Old 02-02-2007, 06:16 PM   #13
spkrman
Drives: 1
welcome to the year 1420 :)
The auto is definitely under 10 seconds, 9.x is what I clocked, although we all know how accurate that is.
Old 02-02-2007, 06:39 PM   #14
Meteorite
Drives: 07 Yaris LB Manual
Are you kidding?
Meteorite is offline   Reply With Quote
Old 02-02-2007, 06:40 PM   #15
Meteorite
I clocked mine at 9.143325456 seconds.
Old 02-02-2007, 07:15 PM   #16
Pars
Drives: 07 Yaris Liftback
The 9.4sec is probably from a normal take-off without over reving and the under 9.0 sec is achieved by giving it some gas before dropping the clutch. Since the Yaris doesn't seem to have much initial (under 2500rpm) power, getting the Rev's up while dropping the clutch should make for a significantly better take-off. Also, I doubt the hard drop with sticky tires will bog down the engine (unlike my old car, which bogged down easily from a hard drop).
My old 98 Civic Hatch has the same weight and power as my new Yaris and that car was rated 8.6sec to 100km/hr, which is very fast considering the gigantic gearings in the Civic's DX engine. The Yaris could be just as fast or faster to 100km/hr if it had some sticky rubber up front. That way, you could burn some clutch, get a jump start, and get the car into the meat of the power at above 3000rpm asap, but the dinky stock tires will have to go in order to support a hard drop.
Pars is offline   Reply With Quote
Old 02-02-2007, 07:39 PM   #17
marcus
toyota
marcus's Avatar
ok now if u throw a short throw shifter and the way i see it each short throw per gear will save you about 1/2 sec.. out of 3 gear shifting will save u approx 1.5 sec.. from 9 sec down to 7.5 might be possible.. dont you think guys...i think i think.....
Old 02-02-2007, 08:23 PM   #18
Biggie™
Biggie™'s Avatar
Drives: '07 3 Door Yaris of Doom!
1. Because of inertia you wont de-accelerate during shifts, the momentum you already generated will continue to push you during fast shifts.
2. If a short shifter saves you 0.5 seconds per shift... And it still takes time to shift even though you now have up to a 30% reduction in throw, how long does it take you to shift with a short shifter? 1.2 seconds... Wow!
3. I'm pretty sure you can hit 60 mph in 2nd gear with a Yaris 5 speed... But I'm not 100%. I know for a fact you wont have to shift 3 times.
A short throw MIGHT save you about 0.25 of a second from your 0-60!
Biggie™ is offline   Reply With Quote
I test drove a Yaris, Versa and FIT CanadaCraig New YARIS Purchase Forum 41 11-29-2008 10:18 PM
Toyota Yaris to Sponsor FOX's "Prison Break" YarisBueller General Yaris / Vitz Discussion 0 04-30-2006 09:01 PM
