Old 01-18-2012, 12:12 AM   #1
momo-yx
Drives: yaris yx
Angry spark plugs problem
what causes this problem ???
this brown color in all 4 plugs
Is it big problem or not ???
momo-yx is offline   Reply With Quote
Old 01-18-2012, 12:45 AM   #2
mr_miles
Drives: 2013 Yaris
I've always thought it's burnt oil, but i could be wrong. is your engine clean or does it have grime?
Old 01-18-2012, 10:23 AM   #3
barryware
that is the result of hot gas's leaking between the metal spark plug body and the ceramic center part.
It is normal and should not be an area of concern but your pictured plugs have more discoloration than I have seen before. It is seen more and more on the "high mileage" spark plugs because they are in service much longer compared to older designs.
How many miles are on the plugs?
barryware is offline   Reply With Quote
Old 01-18-2012, 01:55 PM   #4
Geoff Peace
Drives: Yaris 1.33 litre 2011
This is caused by minute oil particles suspended in the atmophere sticking to the plug because of high voltage. No gas is escaping and it is no detriment to the performance of the plug. If it is very bad (much worse than yours) the spark can track up the face of the insulator, known as corona discharge. Can best be seen as blue flashes in the dark.
Regards Geoff Peace.
Geoff Peace is offline   Reply With Quote
Old 01-18-2012, 03:47 PM   #5
momo-yx
Drives: yaris yx
I'll show you picture, give me some time
5000 miles or less (Always on hi speed )
I think you mean it's not big problem
Old 01-18-2012, 04:15 PM   #6
A-Dingo-Ate-My-Baby
Drives: yaris
I was waiting for this post.
if it was blow-by, it'd have carbon black on it.
A-Dingo-Ate-My-Baby is offline   Reply With Quote
Old 01-19-2012, 01:59 PM   #7
Geoff Peace
It is not a big problem because it is no problem at all! It is worse on cars where the plugs are buried deep in the engine which is most cars these days, and covered either by HT lead caps or as in the case of the Yaris coilpacks. Also as stated the service interval for plugs is being extended, in some cases to 100,000 miles whether plugs are serviceable at this mileage remains to be seen.
Regards Geoff Peace
Old 01-20-2012, 05:57 AM   #8
momo-yx
Drives: yaris yx
Regards Geoff Peace
thank you so much
Spark Plug Problem TickleTimeTim DIY / Maintenance / Service 15 09-07-2013 10:18 AM
Laser plugs? - Awesome Altitude Off-topic / Other Cars / Everything else Discussions 1 04-24-2011 09:02 PM
article on spark plugs and the fit kngrsll Performance Modifications 4 08-02-2009 12:50 AM
did autolite spark plugs screw up coil or coils ?? la_scanner DIY / Maintenance / Service 20 04-09-2009 03:07 PM
Upgraded Spark Plugs For Boost whooppee777 Forced Induction Forum 9 02-14-2009 02:53 PM
