Old 01-24-2012, 07:47 PM   #1
I PHANT0M I
Drives: 2010 Toyota Yaris
My new 2010 Yaris seems slow
It seems slow off the line, reason i say this because my Fiance 2008 Yaris is fast of the line it seems like i have to really push on the pedal to get it going...
Anyone have any ideas what could cause this?
so i can take it to the dealer and see if they can check if there is anything wrong with it
i use 91 octane Fuel if that means anything.
Thank You!
I PHANT0M I is offline   Reply With Quote
Old 01-24-2012, 08:28 PM   #2
Betrivent
Not quite a noob
Betrivent's Avatar
Drives: e46 325
The engine is designed for 89 octane. Using 91 will not:
-Yield significant power gains, if at all
-Get you better fuel economy
-detonate properly (the compression ratio for use of 91 is different then what the 1nz-fe is made for)
Is your car auto or manual?
Old 01-24-2012, 09:19 PM   #3
I PHANT0M I
Its Auto, the only gas available in my area is 85 87 91
Old 01-25-2012, 11:19 PM   #4
PHXDEMON
PHXDEMON's Avatar
Drives: 2007 Red Liftback
The auto Yaris is quite possibly the slowest production vehicle in the states
Old 01-26-2012, 09:23 AM   #5
Yury
Yury's Avatar
Drives: 2008 5 Door Liftback Auto
In terms of 1/4 mile numbers maybe, but on the road there are a lot of vehicles that are slower off the line. Vibe/Matrix for one.
Yaris is not that bad.
even coming off a V6 I find Yaris pretty good in the city. it does run out of steam on the highway though.
1999 Honda Prelude Base 5 speed (summer driver)
Yury is offline   Reply With Quote
Old 01-24-2012, 09:57 PM   #6
CrankyOldMan
2ZR swap. DO IT! Ask how!
CrankyOldMan's Avatar
Oh man, maybe that explains the marginal gas mileage I've been getting since I bought mine last year. I had a coupon for $0.50 off per gallon, so I "splurged" and filled it up with 89. Goes like stink in first, gets up to highway speeds with the quickness.
Old 01-24-2012, 11:09 PM   #7
Hershey
Maybe the trottle body needs a cleaning . Try a few tanks with Techron and 93 octane from Shell or other major gas company . If you do , let us know if any improvement .
Old 01-24-2012, 11:48 PM   #8
Kioshi
Heart Up! Vitz
Kioshi's Avatar
Drives: トヨタ Vitz
Or the OP can just take out the intake and clean the throttle body and save money from repair shops.
Old 01-25-2012, 08:46 AM   #9
I PHANT0M I
Alright i'll surely do that how many times do you think i should do that? Once or twice?
Old 01-25-2012, 11:53 AM   #10
Hershey
Few tanks in a row .
Old 01-25-2012, 12:20 AM   #11
fnkngrv
Mr. 155 and climbing
fnkngrv's Avatar
Is your other hal's ride an auto as well? Is one a sedan and one an LB?
Old 01-25-2012, 07:18 AM   #12
1nzfe engine is designed for 87 octane....not 89
what wheels/tires are on the car? a heavier setup would make it feel sluggish
maybe check the spark plugs? air filter? maf?
Old 01-25-2012, 08:47 AM   #13
I PHANT0M I
Its a 15inch Yokohama tires
Old 01-25-2012, 08:46 AM   #14
Betrivent
Not quite a noob
Betrivent's Avatar
Drives: e46 325
My bad.
Old 01-25-2012, 12:57 PM   #15
malibuguy
Obsessed with 1.5L
Drives: '10 PW Yaris Sedan
I blame the e-throttle...
It seems to adapt to driving style...when i drive aggressive it quickens up a little bit...when im driving like im 87 years old to save gas its dull and delayed
-Greg...the Exhaust Freak.
-82 Malibu, 1uzfe swap
-97 Tercel coupe, 1nzfe/4.31
-96 Tercel 4dr
Old 01-25-2012, 07:44 PM   #16
Bluevitz-rs
Bluevitz-rs's Avatar
Drives: '05 6-Spd Vitz RS
X2
I thuroughly enjoy my cable throttle for consistency
Old 01-25-2012, 05:02 PM   #17
nemelek
DWEED
nemelek's Avatar
Have a real race. See if the car really is slower or if it only seems that way.
Old 01-25-2012, 11:59 PM   #18
Mead
Drives: BSP Yaris LB 2007
+1
Mead is offline   Reply With Quote
2010 yaris suspension advice??? evilekhatch Wheels, Tires and Suspension Forum sponsored by The Tire Rack 4 03-16-2010 09:56 AM
