![]() Drives: 2008 Yaris HB Join Date: Jan 2012
Need constant power to the lighter
Is there a way to rewire the light so it has constant power? Sometimes I need to charge my phone when it's parked and the engine or ignition isn't on.
![]() ![]() Drives: 2005 Echo Rs Join Date: Sep 2010
Sure. You need to find a spot on your fuse panel that's live when the ignition off. One way to 'cheat' is to shove a wire into the fuse slot and then push the fuse in to hold it in place. I have seen a fuse with a wire attached for feeding a circuit at the auto parts store. Just pick a non-essential circuit so that your charger can't take out your signal lights.
![]() ![]() ![]() ![]() Drives: 2009 Meteorite Metallic LB MT Join Date: Oct 2008
You might want to check with CTScott, as he is the electrical guru for the Yaris.
However, also check out a posting he made recently: http://www.yarisworld.com/forums/sho...17&postcount=2 It has a link to his remote start DIY, and I believe it shows a constant 12V power on the fuse block as mentioned by 2005rs above. |
| kuro-kuro, mga sarisaring katanungan | xtremist | Middle East | 2740 | 01-27-2020 03:36 AM |
| Where can i get constant power from? | Syroyizhka | General Yaris / Vitz Discussion | 7 | 04-29-2009 11:08 PM |
| cigarette lighter assmebly no power? | csheller | In Car Entertainment + Electronics (audio / video / alarm) | 6 | 09-23-2007 07:18 PM |
| Constant power, always on, sidemarker lights w/ switch... | reznunt | DIY / Maintenance / Service | 17 | 07-15-2007 11:59 AM |
