Old 01-30-2012, 04:30 PM   #1
I PHANT0M I
Drives: 2010 Toyota Yaris
Swaying Issue.....
Hey guys me again I have another questions for you guys, when ever I'm on the highway or going over 50 MPH my car sways sometimes I could be from left to right... Any ideas???
I PHANT0M I is offline   Reply With Quote
Old 01-30-2012, 04:43 PM   #2
Kioshi
Heart Up! Vitz
Kioshi's Avatar
Drives: トヨタ Vitz
rotate your tires?
hows the thread on your tires?
lots of wind from big trucks passing you by?
are you on stock springs?
Old 01-30-2012, 04:54 PM   #3
I PHANT0M I
rotate your tires?
Tread on my tires are going and quite few trucks are on the highway and also my alignment is also good. And also tires are all rotated
Old 01-30-2012, 05:09 PM   #4
Kioshi
Heart Up! Vitz
Kioshi's Avatar
Drives: トヨタ Vitz
It could be the treads on your tires. When i first lowered my car on new tires, i had to rotate the front right with the front left since it would pull my car slightly to the right.
Install a sway-bar in the rear and I promise the swaying from the trucks will lessen to where you will barely notice it.
Thats all the possibilities that i know of.
Old 01-30-2012, 06:46 PM   #5
I PHANT0M I
really that sounds like a plan how much are sway bars?
Old 01-30-2012, 06:09 PM   #6
RedRide
RedRide's Avatar
I agree, if you do not already have a "rear swaybar", install one before doing anything else.
It's absolutly the "best bank for the buck" as far as ride and handeling is concerned. You will be amaze on how stable the car wiil be with no "sway" or wandering.
Old 01-30-2012, 06:47 PM   #7
I PHANT0M I
Do you know where I could get one?
Old 01-30-2012, 06:51 PM   #8
Bad tires
Bad shocks
Unbalanced wheels/tires
Get a rear sway bar (purchase through Micro Image [PM Cali Yaris here] or try to find one used).
Old 01-31-2012, 11:12 AM   #9
RedRide
RedRide's Avatar
Yes... get one from Micro Image. He is well known here. His Yaris sway bars are the most inexpensive and the quality is first rate.
I personally have a Micro Image sway bar and it's great!
Here is the order page for the sway bars...
http://shop.microimageonline.com/Bracing-Bars_c22.htm
Here is a DIY on how to install it.
It's actually quite simple.
http://www.yarisworld.com/forums/showthread.php?t=14084
Old 01-31-2012, 11:22 AM   #10
ilikerice
ilikerice's Avatar
Drives: 2010 black yaris
could also be just simply road crown.
-Derrick-
Old 01-31-2012, 11:48 AM   #11
Altitude
Altitude's Avatar
Drives: '08 LB MT Bayou
Wider tires (aftermarket rims) and the sway bar stopped my highway wander permanently.
Old 01-31-2012, 03:17 PM   #12
ROCKLAND TOYOTA
TRIM HUNTER
ROCKLAND TOYOTA's Avatar
DITTO
Old 01-31-2012, 06:07 PM   #13
Black_griffin6
Black_griffin6's Avatar
Drives: 09 Meteoric Metallic 3 door HB
This. ^
Wider tires, lowering, and a rear sway bar will make a world of difference.
And I would recommend installing the rear sway bar yourself, just my personal opinion.
Black_griffin6 is offline   Reply With Quote
Old 01-31-2012, 06:47 PM   #14
Kioshi
Heart Up! Vitz
Kioshi's Avatar
Drives: トヨタ Vitz
DIY, you dont need a pry bar to install the sway bar.
I did it in my small one car garage by myself. Just need a torque wrench to torque bolts.
Old 02-02-2012, 01:27 AM   #15
bairjo
For what it is worth, I threw a video together when I installed my sway bar. Not a good video job but shows how easy it is..anyone can do it...if i can.
http://www.youtube.com/watch?v=8RKn7vV4fIo
Old 01-31-2012, 05:41 PM   #16
swidd
Drives: Yaris HB
+1 for the 19mm Micro Image sway bar.
Don't take it to a corporate shop to install. Go to some dirty street garage, because you'll need someone with a giant pryer bar to get off some suspension bolts. Should take 20 minutes and $30.
Old 02-02-2012, 01:54 AM   #17
Kioshi
Heart Up! Vitz
Kioshi's Avatar
Drives: トヨタ Vitz
NICE! bairjo.
Good video.
Old 02-02-2012, 04:12 AM   #18
Vang
Drives: 2008 Yaris Sedan
Do you lose some clearance by installing the sway bar? Is it easy to tell you have a sway bar installed without really looking for it?
I commute 60 miles a day 5x week, so it might be nice to lose some of the highway wander I get.
Vang is offline   Reply With Quote
Water Pump issue, after taking in for Recall GeneralDon7 General Yaris / Vitz Discussion 34 05-27-2012 08:04 PM
2007 Yaris Door Lock Issue bhola General Yaris / Vitz Discussion 7 10-05-2010 12:01 AM
Issue for LP setting on 4 channel amp. YarisSedan In Car Entertainment + Electronics (audio / video / alarm) 6 02-08-2010 12:10 PM
heater control box issue DevilGirl DIY / Maintenance / Service 12 01-08-2010 03:45 PM
CONSUMER REPORTS : MARCH issue reviews '09 YARIS . gid General Yaris / Vitz Discussion 93 01-06-2009 04:10 AM
