SKAR Audio ?
Anybody used these subs yet ?
![]() In a series of new subwoofers to be released by SKAR Audio LLC., the VVX-12 is the second in the lineup! It is our exclusive daily subwoofer that was built in partnership with Jacob of Sundown Audio. This woofer is built to take abuse beyond it's rated power handling of 600 Watts RMS! You will find all of the technical specifications of the driver below, as well as Pre-Order information, which won't last long! Unique Cooling System This Subwoofer has a unique voice coil air flow system with no vent flaring on the back plate. Instead, Jacob designed a system in which the top of pole has an enormous flare and the coil former has vent holes. This creates a nice flow patern through the holes and out the pole (vent). This allows less machining when making the sub and works very well! That system combined with a chrome finish allows for a much prettier finish then most driver's! Progressive Suspension The VVX-12 has a progressive suspension to help prevent mechanical damages. This includes a triple joint re-enforcement ring to hold this joint strongly together at pretty much any power level you throw at them! The VVX-12 Is a great daily driver and will work well in both sealed and vented enclosures. While the driver was tested in both sealed and ported enclosures pre-production, it shined in the vented enclosures on around 600 Watts continuous power. We threw more power then rated at this driver for an extended period of time and it held up without breaking a sweat! Cutout Diameter : 11-1/8" Mounting Depth : 6.5" Displacement : 0.18 Ft^3 Xmaxx : 21.32mm one-way by 70% BL ![]()
Nope! that's too big to put up front, jeje
D.
. CLA 250, 4MATIC |
Roadrunner Jr.
*rubbing hands*
I know of a 13.5" woofer that will fit up front...
“To argue with a person who has renounced the use of reason is like administering medicine to the dead.” ― Thomas Paine |
#4 | |
to sq... but... is that new 13.5" work in a very small vented enclosure? D.
. CLA 250, 4MATIC |
I'm thinking about grabbing a set of them puppies and trying them out. I don't think they're much of an SQ sub but they look like they can make some noise = )
| This Is Why We Use Brick and Mortar Audio shops... | sqcomp | In Car Entertainment + Electronics (audio / video / alarm) | 23 | 06-07-2011 11:37 AM |
| Yaris SR - JL Audio Install + Sound Deadening (Progress Thread) | Nips | In Car Entertainment + Electronics (audio / video / alarm) | 8 | 03-18-2011 12:42 AM |
| Southern/Central NJ audio shop | djgoodonya | NY / NJ/ CT / PA | 0 | 06-12-2010 01:30 AM |
| YARIS SEDAN. PANAMA SISTEM AUDIO GENIUS CAR AUDIO. | JLEE | In Car Entertainment + Electronics (audio / video / alarm) | 4 | 05-13-2010 04:57 PM |
| New Audio Package | YarisRacerRick | In Car Entertainment + Electronics (audio / video / alarm) | 0 | 12-26-2009 11:54 AM |
