08-21-2010, 10:53 PM | #1 |
やりすぎだ~
Headlight Restore
My friend's tC headlights were getting hazy and yellowish after being untouched for 5 years.
I thought I'd give this restoring thing a try - it can't get any worse than it is now. I bought the Mother's Headlight Restore since it was on sale. In the end, you can still see some scratches and blemishes up close, but overall, not bad for a couple of hours. |
08-21-2010, 11:12 PM | #2 |
A great improvement.
08-23-2010, 04:14 AM | #3 |
Mothers is a awesome product, good job.
10-14-2010, 12:15 PM | #4 |
Drives: 01 Toyota Echo Join Date: Oct 2010
I've used the rainx product. It worked fine, just be liberal with the lubricant and really go to town with the headlight polish, wash it then really spray down and rub in the sealant.
10-14-2010, 04:22 PM | #5 |
Mr. 155 and climbing
I am wondering how the EuroLight product would work compared to the Mothers.
10-14-2010, 06:56 PM | #6 |
Drives: '09 Yaris carmine red 2d HB Join Date: Jun 2009
10-15-2010, 03:45 PM | #7 |
Hooch Brewer-Shine Sipper
That's great! I've got a '98 Avalon that looks like it has glaucoma!
10-17-2010, 09:01 PM | #8 |
Drives: Scion FR-S 2013 Join Date: Aug 2010
Brother that stay like new. Good job.
04-14-2011, 03:58 PM | #9 |
50,000 miles, Yeah!
Drives: 06 3 door Black Join Date: Apr 2011
I used this kit last night on the 3 door and it did a pretty decent job. I am a bit of a perfectionist but it sure did more good than bad. Our Yaris started to get bad and hazy last year and got worse almost monthly. I hope that it will last a while till I need to do it again.
That is what happens when you live in the desert at 4500 ft elevation. But thankfully we garage it most of the time.
Mods: Factory Spoiler, K&N Air Filter, Cool Pedals, and Shifter Knob with lather turned spacer. Working on Black out badges now. |
07-16-2011, 06:37 PM | #10 |
Drives: 2008 Yaris Liftback (Sprocket) Join Date: Oct 2008
I've been reading the reviews on Amazon.com on this product and for the most part they have been positive.
Disappointingly, the tops of my 08 LB headlights are already starting to cloud. Of course, I do live in southcentral Texas where the sun can be pretty severe. I almost bought this kit today at Walmart but decided to hold off until I did a little research. A few did claim this product made their headlights worse! That said, we had the headlights on our 2005 Honda Odyssey "professionally" done while it was in the shop and they are not crystal clear either. I don't think that such a level of restoration is even possible...
07-17-2011, 12:02 AM | #11 |
やりすぎだ~
I recommend you use it ONLY if the lens is completely faded. In your case, I don't think you should use it yet. You're right - after using it, it doesn't return back to it's original state. It's still a bit blurred after I was done, but since it was really bad before, it was much better after. Another thing, I highly recommend using sandpaper with grit 1500 then 2000, wet-sanding is a must. It takes a lot longer but comes out better. You'll still see the 2000 grit scratches though.
The ones that claimed it made their headlights worse were probably because of two reasons. The lens probably wasn't that faded, but they tried it and found out that the sandpaper made scratches that the polish couldn't remove. The other reason was probably they didn't spend enough time on the sanding (esp. with 2000 grit). |
07-17-2011, 11:01 AM | #12 |
resident senior
Newsflash : ANY wax will do the same . That's right , any wax that you wax your car with will do the same thing . Personally I use Meguires NXT tech wax 2.0 .
Whenever I wax my Yaris (3 times a year : Pre and post pollen ,then again before winter ) I wax the head and tail lights . My Yaris sits outside in the sunshine pretty much all day everyday . Check the pics ...
08-13-2011, 03:31 PM | #13 |
Drives: 09 Yaris Join Date: May 2011
Ah I missed this when I posted about the film on the headlights. Is there a way to prevent this from happeneing? Is waxing the answer?
08-15-2011, 09:04 AM | #14 |
JOE GIRTH
Drives: YARIS 3DOOR Join Date: Feb 2007
ive tried some plastic polish on my all red tails that got hazed up from the cheap clearcaot applied. While it tOOK away some of the mess it stillS STILL DULL....
http://www.carid.com/toyota-accessories/ site has a FEW interesting yaris items..... |
08-29-2011, 11:41 PM | #15 |
Drives: good Join Date: Aug 2011
Cloudy headlights affect hundreds of thousands of vehicles in virtually all makes of cars and trucks, domestic or foreign. Headlight restoration or repair of the lighthouse is the process of cleaning the lens of the flashlight or headlamp kits with items sometimes found in your local auto parts store. Save money on expensive replacements, which recover, quick and easy, the best thing anyone can do it without any training or special tools.
epiphone |
11-18-2011, 01:44 AM | #16 |
Drives: toyota Join Date: Jun 2011
Great product and great work.
01-09-2012, 08:15 PM | #17 |
That looks great. Did you wetsand at all? Definitely helps
01-09-2012, 10:19 PM | #18 |
やりすぎだ~
Yes, wet sanded because was pretty bad. If the headlights aren't that bad, you could probably do it without sanding. This is not a permanent fix though. It has to be repeated every few months, depending on how much you drive.
Thread Tools | |
Display Modes | |
Similar Threads | ||||
DIY Projector/HID (sedan) | Brian | DIY / Maintenance / Service | 145 | 02-05-2012 04:13 AM |
Silverstar Ultra 9003/HB2 vs OEM headlight bulb comparison | CTScott | DIY / Maintenance / Service | 54 | 02-14-2011 08:58 AM |
How To Smoked Sedan Headlight -DIY | zulhizainL902S | DIY / Maintenance / Service | 26 | 01-14-2011 02:12 AM |
Glassylite Headlight Restoration Kit | TEHxFALLEN V1.2 | Photo-Video-Media Gallery | 1 | 07-03-2010 12:51 AM |
HELP! I detailed my interior, and now having a headlight issue! | Astroman | DIY / Maintenance / Service | 4 | 06-08-2010 06:51 PM |
