Old 05-17-2011, 06:58 PM   #1
heeroyuy01195
Post count means nothing.
Drives: AW11, NCP91, Old Motorcycles
Steering Wheel question
Hi all,
does anyone know if a 2010 scion tc steering wheel will fit our cars and still retain function of the airbag? Are there any other options out there for a solid colour leather steering wheel? I read that the xD and xB steering wheels fit but they only come in two-tone leather. I want an all black leather steering wheel but I want to retain use of my airbag and also keep an OEM look. Thanks in advance.
heeroyuy01195 is offline   Reply With Quote
Old 05-18-2011, 01:28 AM   #2
bzinn 1
bzinn 1's Avatar
Drives: 2008 Yaris HB
The steerign wheel from the tC fits,that is what I put in mine....came out of a 2006 tC....dont know about the new tC if it will fit or not.
Mine I was able to bolt the thing in like it was stock,the airbag is not a perfect match fit tot eh wheel curves but it is close enough and feels way better than the plaxtic one that came in the car stock.
Pretty sure there is a picture on the thread Divorce forces me to modify of mine installed,most likely the last page.
To install it I found that a small tab on the wheel needs trimmed off,it gets in the way of how the wheel lines up with the blinker return ring.
Old 05-19-2011, 08:16 AM   #3
heeroyuy01195
Thanks for the tip bzinn. Did you just swap over the airbag system from the Yaris wheel to the tC wheel? The wheel I'm getting is from the 1st generation tC (bought in 09 as a 10 model), not the new one that came out recently.
Old 05-29-2011, 10:15 AM   #4
heeroyuy01195
Anyone have any information on using the leather Corolla S steering wheel?
http://www.yarisworld.com/forums/showthread.php?t=12650
Old 05-29-2011, 12:02 PM   #5
bzinn 1
bzinn 1's Avatar
Yep just transfer the airbag over to the new wheel.....very close to perfect fit on the cover on the angles of the curves....you will see...it works good.
Not sure about the Corrolla wheel.
Old 05-30-2011, 12:28 PM   #6
heeroyuy01195
Thanks bzinn. I don't suppose you would know if the scion airbag could be wired to work on the yaris would you?
Old 05-30-2011, 06:27 PM   #7
Any Toyota/Lexus/Scion dual squib airbag will work. If you find a wheel with a single squib airbag, then to use it you would have to connect a 3ohm resistor across the second airbag connector to keep the SRS ECU happy.
Old 05-30-2011, 10:34 PM   #8
heeroyuy01195
Scott, thanks a bunch for that bit of information; that really helps a lot. When I eventually get my hands on the wheel do you mind if I shoot you a PM when I do the installation? I'll be putting up a full write-up when I get around to doing this.
edit: I know this might be a bit late but...will I need to do anything to get the horn to work?
Old 05-30-2011, 11:36 PM   #9
Definitely hit me up if you have questions. The horn will connect the same.
Old 05-31-2011, 07:58 PM   #10
marcus
toyota
marcus's Avatar
Drives: 2007 Yaris RS Blazed
i would love to get 2011 scion tc steering wheel on my yaris...
If my calculations are correct, when this baby hits eighty-eight miles per hour... you're gonna see some serious shit!!!!!!
"Horsepower is how fast you hit the object. Torque is how far you move that object.."
Old 05-31-2011, 10:30 PM   #11
Betrivent
Not quite a noob
Betrivent's Avatar
Drives: e46 325
If anbyody wants to take the dive and make a DIY.. here's a wheel on ebay.
http://cgi.ebay.com/ebaymotors/OEM-S...s#ht_500wt_956
I think Scott could tackle it easily ;)
Old 05-31-2011, 10:48 PM   #12
I actually have a Scion TC leather steering wheel on Crashy. The Yaris airbag cover doesn't fit it perfectly, so ideally you would want the TC airbag:
Old 07-21-2011, 11:44 AM   #13
PROX4x4
1.5 or 2.5 both=0-60 in 8
Drives: 08 Toyota Yaris
Scott,
Do you have the door lock actuators from the Crashy somewhere? I am looking into installing those in my car (08 2dr).
PROX4x4 is offline   Reply With Quote
Old 07-21-2011, 11:47 AM   #14
Originally Posted by PROX4x4 View Post
Scott,
She was all manual for locks and windows.
Old 03-02-2012, 07:04 PM   #15
tk1971
tk1971's Avatar
I just cut a piece of hard rubber, lifted the bottom spoke leather cover of the TC steering wheel and glued it in. I then glued the leather onto the hard rubber.
I could have done a better job fitting it with my airbag, but I got lazy and eyeballed it. Looks like the spoke is now touching the airbag, but there's a small gap.
tk1971 is offline   Reply With Quote
Old 07-23-2011, 02:42 PM   #16
heeroyuy01195
Well this was supposed to happen a long time ago but unfortunately the guy I was getting the wheel from backed out. I've since put the money towards my other car as I'm trying to just get the damn thing finished already (on-going project since 04'); Yaris is on the back burner now (although it did make out like a bandit and get some goodies out of me before the decision so I've got some stuff I need to install on it).
Old 07-24-2011, 04:16 AM   #17
caineroad
caineroad's Avatar
Drives: 06 Yaris HB CE
i want to know if 2011 wheel can do it
caineroad is offline   Reply With Quote
Old 07-24-2011, 07:19 AM   #18
The airbag cover is completely different on a 2011, so if the spline is still the same it will fit, but you'd also need the complete airbag assembly.
DIY - 2009 Cruise Control for $10, without pulling the steering wheel and airbag CTScott DIY / Maintenance / Service 307 04-04-2023 03:43 AM
The Yaris Steering Wheel wornways General Yaris / Vitz Discussion 12 10-09-2012 01:41 PM
How much would you pay for a warranty supported steering wheel extension? (3d try) wornways General Yaris / Vitz Discussion 36 09-16-2009 10:16 AM
OEM foglight switch and leather wrap steering wheel 808yarisLB Cosmetic Modifications (Exterior/Interior) 8 03-11-2009 12:05 AM
SCION SPORT STEERING WHEEL, RED, XA AND XB, 03 TO 06 justoneyaris Items for Sale by private party 3 12-04-2008 06:30 PM
