![]() Drives: 2007 Yaris sedan Join Date: Apr 2012
Hi everyone. My car is totally dead. There are no lights showing on the dash at all. The symbol in the factory battery shows OK, but I can't even turn the key. Any suggestions???
![]() ![]() ![]() Drives: 2007 Liftback Join Date: Mar 2012
Check your connections.
2ZR swap. DO IT! Ask how!
Have you tried rotating the steering wheel? I've had the steering lock engage a few times to where it wouldn't allow the key to turn until you released the pressure on the tumbler. If not, then you may need to replace the tumbler. If that happens, then you need a new key, and possibly an ECU re-flash to get the ignition disable thing to work--assuming you have that feature.
Not quite a noob
Do you have an immobilizer? To check, see if your ignition cylinder has a black plastic ring around it.
#5 | |
Drives: Toyota Yaris Spirit Join Date: Apr 2012
Hi everyone!Thanks for your imput. I tried boosting the car... it started smoothly. the daytime running lights came on after a couple of minutes. I let it run for 10 or so minutes. Once I turned off the engine, the dome light is very weak as well as the only symbol on the dash ( door ajar ). Now, after two hours, the ignition switch can be turn but no response...only the engine,battery, door ajar and oil lights showing on dash. When turning the key to start position I can bearly hear a very weak sound.
Need new battery.
bam! problem solved, close thread
DAT'S RIGHT I GOTz 2
^+1
just because your battery (dumdum) eye says ok your battery still could have a bad cell
Many thanks "YarisTeam" !!!
![]() ![]() ![]() ![]() Drives: '07 Yaris HB Join Date: Apr 2006
This is what happened to my car the other day, and it turned out to be the battery. Just replace and drive on my friend!
![]() ![]() ![]() Drives: 2012 toyota yaris Join Date: Jan 2012
sounds like your battery took a crap on you, similar thing happen with my evo, about a year ago. changed the battery out and it went back to normal
2012 yaris L model 2014 wrangler unlimited sport |
| 6x9 speakers in front doors | dawin2122 | In Car Entertainment + Electronics (audio / video / alarm) | 56 | 11-05-2011 03:55 PM |
| Response from Toyota on my special order | drdavidr4u | New YARIS Purchase Forum | 14 | 04-27-2010 08:59 PM |
| Not Clean Yaris (a response) | MWill517 | General Yaris / Vitz Discussion | 17 | 03-27-2007 05:01 PM |
| 10" Type R in TCAB - Freq response - vid | spkrman | In Car Entertainment + Electronics (audio / video / alarm) | 3 | 03-20-2007 03:53 PM |
| Response from Toyota | Driver | New YARIS Purchase Forum | 22 | 09-04-2006 07:44 PM |
