![]() ![]() ![]() ![]() Drives: 2010 Yaris S Join Date: Apr 2010
Does Toyota put loctite red on the rear strut bolts??
Hey all,
was installing my tein springs..the front was cake, the rear has been a nightmare, in fact broke two craftsman socket wrenches trying to remove the rear lower strut bolts! My 08 was easy to remove, these seem like they are seized or they have loctite red on them anyone else experience this? I have a 15" 1/2 breaker bar with 14mm socket that won't fit where I need it to thanks to the rear drum assembly
"In his heart a man plans his course, but the Lord determines his steps." Proverbs 16:9 |
I swapped suspensions on an 08 and 2010 yaris, along with an 09 xd and the rear bolts came off like nothing..maybe jack up the drum so there's less stress on the bolt? Possibly loosen up the bolt before jacking the rear end, assuming you're still at the oem 4x4 height.
man I did it all and this thing will not move! sucks, this bolt has turned all my tools into it's bitch
Just the opposite. Installing springs on the rear was far easier. Had no issue with the bolts. Sure your perspective isn't off and you've actually been trying to tighten them? Never hurts to ask.
lefty loosey righty tighty right
Put a torch to the nut. A little heat can go a long way.
already tried that this bolt has turned fire into it's bitch
electric impact wrench ftmfw!
I don't understand why you can't get your breaker bar & socket to clear the drum.
![]() ![]() ![]() Drives: Black '08 Yaris Hatch S Join Date: Aug 2011
Beat it with a hammer and throw some wd-40 on there.
-Will- |
Cut 'dem bitches off with a torch!
I'm not saying that the OP did no know this but, I'm always amazed at the grown men who actually do not know this..... either at my former job (now retired) or, in my day to day encounters
Personally, my dad instructed me on this when I was about 3 years old. |
got the bolt off! Sprayed it with Liquid Wrench, waited 10 minutes and voila!
Stupid me. I'd assumed you'd already hit it with some product.
Unless your working on british cars the lugnuts on left side are removed turning left and right side are removed turning right.
![]() ![]() ![]() ![]() ![]() Drives: red bare bone yaris hb 3dr Join Date: May 2009
Had the same Problem before . Lucky you can take them out ... On my case I had to bring the car to a local shop and they need to cut them with an air saw ... 10 minutes and $300 later ... They put the new struts in .
Tried to argue with the shop " why I have to pay $300 for a 10 mins job ??" they said theyre just following the labor manual on those thing.... I was like F yu guys ... You just lost a returning customer .. |
OP -for future reference, always try to use an alloy socket. they are far stronger that that "stainless steal" looking crap. almost all impact tool sets come with alloy sockets. i learned the hard way also when removing the torx bolts holding down my back seat.
| Need input on ULTRA RACING 23MM SWAY BAR VS NITTO REAR LOWER STRUT BRACE. | marcus | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 18 | 02-22-2011 08:32 PM |
| CAN TOYOTA RETROFIT NON-FIXED REAR WINDOW? | pennsylvania girl | Cosmetic Modifications (Exterior/Interior) | 8 | 04-22-2007 02:47 AM |
| Toyota Delays | Buckethead | General Yaris / Vitz Discussion | 3 | 08-26-2006 04:16 AM |
