Old 05-23-2012, 05:47 PM   #1
jonhy_ sm
Drives: Yaris '07
yaris 1.0 1krfe gearbox oil
Hi there.
Can someone tell me what kind of oil is used on the gearbox of a yaris 2007 1.0 1krfe engine code.
When should I change it?
How much oil does it use?
If you have a diagram showing the holes to empty and refill it , I would appreciate it as well.
Regards
jonhy_ sm is offline   Reply With Quote
Old 05-24-2012, 09:53 AM   #2
The 1krfe is either paired with the C551 or C551A multimode manual transaxle.
The recommended gear oil change interval is 60,000 km for both.
The C551 has a capacity of 1.7 L of 75W-80 gear oil
The C551A has a capacity of 1.4 L of 75W-80 gear oil
In the image below the part labeled 33104 is the drain bolt and 33101A is the filler bolt.
Yaris Oil Change DIY rningonfumes DIY / Maintenance / Service 91 01-11-2019 07:18 PM
'09 Yaris Oil Pump Gear Size? wright784 DIY / Maintenance / Service 1 05-13-2009 06:15 PM
