Water Pump issue, after taking in for Recall
Ok, so today I took my 2007 Sedan, into get that recall seatbelt issue fixed, by the way, I havent noticed any difference in outside noice. I was told that my water pump was malfuctioning an they have to replace it, even though the car never showed me the check engine light, the toyota person told me, that it wasnt a big issue, so I scheduled it for 2 saturdays from now. Has anyone else had this issue?, its covered under warranty, so its a free fix either way, i was just curious how commmon this was. My car has 40000 and is 2 years old. Good thing I havent gotten the water pump pulley upgrade yet.
![]() ![]() ![]() ![]() ![]() Drives: . Join Date: Feb 2007
I have a 2007 Hatchback, about 32000 miles on it, and no problem yet. i'll be curious to see what other folks have to say, though.
#3 | |
![]() ![]() ![]() ![]() ![]() ![]() Drives: 07 Yaris 3dr LB (Bayou Blue) Join Date: Oct 2008
36k no problems?? :S
-Jen <3 ![]() Quote:
Drives: 2007 Toyota Yaris Hatchback Join Date: Jan 2012
My 2007 yaris hatchback has over 250,000 on it with all original parts minus the break pads/shoes, sparkplugs, oil filters and whatever they change during regular maintances...which we kept doing.
good little car. Im thinking maybe the water pump is finally starting to go....a whiring sound from motor area...grindy. will check for water leaks
#5 | |
toyota
easy to tell check the inside part of the pulley you should see pink stuff if its leaking..
If my calculations are correct, when this baby hits eighty-eight miles per hour... you're gonna see some serious shit!!!!!! "Horsepower is how fast you hit the object. Torque is how far you move that object.." |
i had problems with both the alternator bearings and the water pump getting ceased up.
a little over 2 years old, and 56000km when both was changed. |
15,000km and no issue with water pump.
![]() "Manual labour is not for me. In fact i'm not even sure non manual work is either." -Anthony Linton Check out ▬▬► I like I like ◄▬▬ for more fun on Facebook |
![]() ![]() ![]() Drives: Toyota Yaris 1,8 TS 5dr. 2007 Join Date: Dec 2008
Hi
If the water pump need replacing it won´t put a check light in the display. It will leak water and perhaps it´s not very much, but when it´s on the guarantee it doesn´t matter. I work at Toyota and I think we have replaced only one on the guarantee on a Toyota Yaris. Regards Steven. |
Water pump failure is not uncommonon the 2004-2006 Scion Xb's. If you check over on Scion life you will see it is actually quite common. In fact on my 2005 Xb with 59,000 mile is starting to show a little dried coolant "crust" under the weep hole, so mine is on it's way out too.
PS- Yaris and Xb have the same motor, though I'm not sure the water pump is identical... |
echo prius xa xb and yaris share same water pump....
ah, i haven't had prob with my 05 echo with 60000km. (2 years old when i sold it)
School'er of hard knocks
Drives: Silver Yaris 4dr. HB Join Date: Oct 2008
Surprised they covered it. IIRC the water pump does not consist of the "powertrain", thus falling under the bumper-to-bumper warranty (which should have expired with that kind of mileage).
Ha, don't know too many folks who actually get those (as they are usually a rip-off).
on my last yaris the waterpump went bad with under 15ooo miles. http://www.yarisworld.com/forums/sho...=waterpump+diy
toyota
had mine replaced at 80k kms but it might have been leaking since 60k
advocatus diaboli
I'm not going to tell you it's been hundreds of thousands of miles with no problems, because I don't want to jinx myself. ;)
| electric water pump help! | mandriu | Performance Modifications | 39 | 10-24-2009 02:56 AM |
| bye bye water pump | cali yaris | Performance Modifications | 29 | 01-03-2009 05:06 PM |
