Old 06-04-2012, 02:48 PM   #1
47_MasoN_47
What I thought I'd do was
47_MasoN_47's Avatar
Drives: 09 Yaris Sedan
Unhappy My 86.5 Nissan hardbody needs help!
Vehicle involved is my project truck - 1986.5 Nissan Hardbody (D21) 4x4. VG30i, King cab, etc.
I'm not sure if it's a bearing or what, but I was going down the highway (~60-65mph) this weekend after a camping trip and I heard a popping noise then something like the sound of someone dropping a few pennies. Shortly after this an absolutely horrid noise started coming from the front driver's side wheel. It's insane loud, and caused the truck to start shaking. I was about out of gas so I slowed down a bit and pulled into a gas station where I didn't see any fluid leaking or anything. As I was slowing down the whole truck shuttered and made another loud pop/grind noise and the noise from the wheel stopped. After I left the gas station the noise didn't start back up until around 35mph, which it continued to do until I pulled in my driveway. The truck stopped normally and it didn't seem like there was any resistance on the wheel (I could let go of the steering wheel and the truck didn't pull to the left or anything). I looked and it appears that there's a ton of grease that has sprayed out from somewhere behind the wheel. It's fresh (doesn't have dirt and crap stuck in it) so I'm 99% sure that it came from whatever went wrong. I touched the rim and it was hot enough to cause my hand to turn red.
So... do you guys think it's something wrong with the 4x4 (it wasn't in 4x4 when this happened) automatic hub deal or perhaps a wheel bearing? I'm not sure how to even find out what's broke.
Old 06-04-2012, 11:00 PM   #2
racerb
Sounds like the wheel bearing is coming apart and has forced the seal out. The fact that it's a 4x4 makes it a little more complicated, but check Rock Auto Parts, they might have a diagram also!! I owned 2 Nissan Hardbodies, an '88 and a '93, but neither was four wheel drive, so not really good with locking hubs! Go to www.rockauto.com and look under D21 Pickup for inner and outer bearings and hub seals.
racerb
racerb
'86 Celica GT
'87 Celica GT-S
'98 Rav4L
'01 Tundra SR5
Old 06-05-2012, 12:57 AM   #3
47_MasoN_47
Thanks for the info!
Old 06-05-2012, 11:51 PM   #4
Spidermandud
Spidermandud's Avatar
Drives: Black '08 Yaris Hatch S
I asked a fella at work today who's familiar with these, he said make sure to check your transfer case which should be on the driver's side and make sure it's still juiced up and that it hasn't popped something as well.
-Will-
Spidermandud is offline   Reply With Quote
Old 06-06-2012, 12:51 PM   #5
47_MasoN_47
I think I have multiple problems. The CV boots are both FUBAR and the brakes are dragging. Some of the guys on InfamousNissan said that I should replace the CV, calipers, possibly rotors if they are damaged, and then the wheel hub/bearing if it's damaged as well. They said that I should bleed the brakes, I'm not really sure how to do that though.
BTW here's a short video I made while the wheel was off. http://www.youtube.com/watch?v=IByXYA7TaN4
86 nissan pickup - worth $1k? 47_MasoN_47 Off-topic / Other Cars / Everything else Discussions 17 03-07-2012 03:09 PM
2011 NISSAN JUKE!! 4 dr hatch awd turbo. marcus Off-topic / Other Cars / Everything else Discussions 35 09-12-2010 01:18 AM
NEW NST Kit for Nissan 370Z & Infiniti G37 VQ37HR Dyno! NonStopTuning NonStopTuning 0 08-27-2009 07:28 PM
nissan altima wsladaritz In Car Entertainment + Electronics (audio / video / alarm) 2 01-26-2009 04:40 AM
2009 Nissan Cube PaulMedley Off-topic / Other Cars / Everything else Discussions 3 11-26-2008 08:07 PM
