![]() Drives: 2007 1.3L AWD (auto) Vitz 5 dr Join Date: Aug 2020
Coolant Temperature Gauge Anyone?
Has anyone installed an analog coolant temperature gauge? I'd like to know exactly (more or less) what is happening — at least more than the LED tells me. Japanese summers can be hot and very humid.
I'd ideally like an oil pressure gauge and an oil temperature gauge, but for now I'd be satisfied with knowing what my coolant is doing. I did a search and nothing came up. I'd be reassured by hints of how to rig it up on a Yaris. |
![]() ![]() ![]() Drives: Starlet Join Date: Nov 2017
Couple of options. You can put an inline temp sensor in the bottom or top radiator hose or you could buy a OBD2 gauge like an aem x-series or a scangauge
![]() Drives: 07 yaris 3door Join Date: Sep 2007
get a cheap bluetooth OBDII reader - it plugs into the obd port, and then get an app for your phone (there are several - try dashcommand or torque to start off with) and you'll be able to see quite a few things that the car already has sensors for (water temp being one of them)
#5 | |
WOW ... you sure did! I don't think I will be following you. But it sure looks what I would like! Well, not quite. My 2007 1.3L AWD AT type is a pretty sedate, boring driver. Still, coolant temp would be great — even if I can't have oil temp and pressure.
This may be a dumb question, But is what your suggesting mean I have to know the port entries for the scan connection, and then have my smart phone reading something — I'm not really understanding, because I've been driving dinosaurs for so long. |
| What is a (or the) coorect coolant & amount for a Yaris? | RMcG | DIY / Maintenance / Service | 0 | 06-19-2019 05:36 PM |
| Low engine coolant temperature indicator light -> stays on for 5 minutes... normal ? | zimso | General Yaris / Vitz Discussion | 3 | 10-19-2010 07:17 PM |
| Engine Coolant Temperature | djino | General Yaris / Vitz Discussion | 18 | 07-16-2007 12:26 AM |
| Temperature gauge | fearturtle44 | General Yaris / Vitz Discussion | 1 | 05-18-2006 08:54 AM |
