![]() Drives: yaris Join Date: Sep 2011
Help on My A/c
My yaris 2006 compressor was failed and I replace it with after market compressor. After replacement same day it works fine, after that If i start in the morning it took 6-8 Minutes to start the compressor after switching on the A/c and green light is coming.
Why the delay is coming?Is refrigerant pressure low/high? Please advise me. Thanks in advance |
Did you have a mechanic evacuate and charge the A/C system after replacing the compressor?
Yes, He checked and said may be issue with control board. Once the A/c starts to work, it works fine for hours no issue.
Only initial delay after stopping for 5 to 6 hours. Since in the morning i have to drive only for 10 Minutes, in hot summer here it is very difficult to drive inside the car without A/C. Please explain me why these starting delay, Here(UAE-Fujairah) the mechanic is not good, & I yet to find the good one. |
#4 | |
Thanks for your reply, low pressure was around 60psi @ 40 Deg ,I will check the both by tomorrow & post here.
That should be OK as it should be 57 to 85 PSI with the compressor not running.
Cooling is not the issue only delay in start of compressor, Mainly after long gap keeping vehicle OFF.
If I run the vehicle in middle after 1 Hr, No issue, compressor starts to work immediately!! |
That makes me think the pressure is low and the heat of the engine running increases the pressure enough to let it decide to start.
The mechanic checked the pressure said Ok, but the clutch is not working properly and asking me to change the compressor new. Is it correct?
That's an expensive repair, so I would ask him to prove what the clutch issue is.
| A/C Not Blowing Cold Air...among other things | yarisitis | DIY / Maintenance / Service | 38 | 07-28-2016 04:00 PM |
| DIY: Unlink A/C from Defroster | stran | DIY / Maintenance / Service | 46 | 01-19-2015 09:17 PM |
| A/C compressor | yaryar83 | General Yaris / Vitz Discussion | 3 | 06-03-2012 09:47 PM |
| A/C Broken On My 2010 5 DR HB | ChilliwackGuy | DIY / Maintenance / Service | 15 | 07-14-2010 04:33 PM |
| Easy Defrost A/c running fix | billk | General Yaris / Vitz Discussion | 14 | 01-16-2009 08:53 PM |
