Spin out and engine shutoff?
I didnt know which forum to put this in, so my apologies if this is the wrong place. So earlier today, it was raining pretty bad. After leaving the gas station i entered the rotary. As i was going around the rotary, i could feel myself start to hydroplane a lil. When my rotary exit came up i went to take it, and instead, ended spinning 180 degrees, counterclockwise. Scared the shit outta me. Luckily i didnt hit anything
There isn't an inertial shutoff, so the reason for the stalling could be fuel starvation, particularly if the tank was low, as the Yaris gas tank doesn't have any baffles to keep the gas from sloshing.
I assume it's an AT, otherwise the other likely stall cause could be stomping on the brake without pressing the clutch.
yes its an automatic. fuel starvation? i had just filled up prior to incident....
could a full tank of fuel have sloshed around enough to cause the starvation?
No. If it was full, that wouldn't do it.
I don't think so. Since it started back up and doesn't have the MIL lit, chances are that you didn't do any damage.
