Old 08-21-2012, 02:49 PM   #1
Nightangel451
Drives: 2012 Yaris SE (Manual)
Reasonable MPG or not?
I brought my Yaris a little under a month ago and just filled my gas tank for the second time. I did my MPG calculation, and got 26. This is obviously lower than the average stated by Toyota. Does it fall in the realm of reasonable? Some things to note:
- It's been HOT here (hitting 100 F most days). The A/C in the car has been running pretty much constantly at mid-high levels.
- 95% of my driving has been "City" driving. This includes commuting 2 miles each way to my office. I calculated I stop-and-go an average of 6 times in that distance, one way.
- Car has 4800 miles total.
Thanks for any help/advice you can give. This forum is awesome; it already helped me realize the low coolant temp warning I was seeing was normal.
Nightangel451 is offline   Reply With Quote
Old 08-21-2012, 03:27 PM   #2
edmscan
edmscan's Avatar
Drives: 2020 Corolla
I personally find that to be low .. but I pretty much never drive with the air conditioner on .. so I really don't know how much that affects your mileage. The one thing that I find helps .. is DFCO on the Yaris. All I know is that the Yaris is capable of some pretty good numbers so there is always room to improve.
edmscan is offline   Reply With Quote
Old 08-21-2012, 04:44 PM   #3
bentjazz
Drives: 2009 Yaris--3dr MT
I have around 13,000 miles on my Yaris, and am only now getting the kind of mileage that I expected when I first bought my car. I don't know why it's taken this long, but my best tank this summer was 38.36mpg and I haven't gotten below 37mpg this summer. I keep my tires inflated at around 40psi, keep my speed down as much as possible, and coast whenever possible. I'm betting your MPGs will go up as time progresses and as you become more comfortable with the car, particularly since you have a 5 speed. I'm getting my MPGs with an auto tranny....I can only imagine what I'd be getting now if I had a stick. My two big regrets in buying my Yaris---not buying a 5 speed manual and buying a black Yaris (hard to keep clean).....
Other than that, I'm happy.....
bentjazz is offline   Reply With Quote
Old 08-21-2012, 10:26 PM   #4
edmscan
edmscan's Avatar
Interestingly . . I have a 5 speed and wish I had an Automatic (from what I have seen on the forum here .. the mileage is about the same) .. and I do have also a Black Yaris .. and I will have to agree, Black is a pain to keep clean. I think that white would have been a better color to have.
Old 08-21-2012, 11:40 PM   #5
roadrunner
Yaris Hypermiler
roadrunner's Avatar
Drives: 2007 Silver Liftback
"Does it fall in the realm of reasonable?"
YES, considering what you wrote.
roadrunner is offline   Reply With Quote
Old 08-21-2012, 11:58 PM   #6
nookandcrannycar
Wow! Other than tire psi, slower speed/acceleration, staying in the highest gear possible, limiting A/C.....what else are you doing to get the MPG numbers that you are getting?
Old 08-22-2012, 04:29 AM   #7
DJYojimbo
Drives: 2012 Grey Toyota Yaris SE
If u have cruise control i would use it. I use my cruise control all the time time as long as i'm not too close to other drivers. The MPG gauge helps a lot too!
DJYojimbo is offline   Reply With Quote
Old 08-23-2012, 07:03 PM   #8
nookandcrannycar
Unfortunately the '07 MT liftbacks (and possibly all '07s?) don't have the MPG gauge that the '12s have . I haven't added cruise control yet. Good to know you feel it helps re MPG. Thanks for the info.
Old 08-23-2012, 07:12 PM   #9
edmscan
edmscan's Avatar
According to my ScanGauge .. I get better fuel economy when I drive myself as compared to my cruise control. I haven't really gone for a long road trip to test this out .. but just viewing the scangauge info this appears to be the case.
Old 08-22-2012, 10:40 PM   #10
roadrunner
Yaris Hypermiler
roadrunner's Avatar
how to get mpg numbers
I do nearly everything possible. It would take pages to mention.
Some quick stuff............
Scanguage II
Grille block
No air ever
EOC often
Only use my Yaris to and from work, total mile 40, rolling hills
I drive off hours to and from work
Stay off the highway
oversized LRR tires at 44 psi
Coast up to lights and stop signs
I do not hold up traffic!
More stuff go to CleanMPG for tips on hypermiling
Roadrunner
Old 08-23-2012, 08:12 PM   #11
nookandcrannycar
Scanguage II
Grille block
No air ever
EOC often
Roadrunner
Thanks for the thoughtful reply. Some of these things I'm already doing (but neglected to mention) and some of them I'm not willing to do (44 PSI, no air) and I'll definitely check CleanMPG for tips. The tip that you are using that intrigues me the most is grille blocking. What are you using to block your grille?
Old 08-24-2012, 04:34 PM   #12
roadrunner
Yaris Hypermiler
roadrunner's Avatar
grille block
Wall molding that goes along the floor in a room. Used goop to apply it.
I leave it on the Yaris year round.
Old 08-25-2012, 09:46 PM   #13
rick996
rick996's Avatar
Drives: 2010 5 door hatch w/5 sp man.
No air ever
Roadrunner
I do use my AC, but only going down hills in DFCO. Leave it on recirculate and you can be much more comfortable. I also unlinked the AC from defrost.
rick996 is offline   Reply With Quote
Old 08-22-2012, 09:34 AM   #14
bentjazz
edmscan,
I hear ya. I really wish I would have bought a white or silver Yaris. Oh well, now I'm stuck with my black tinted window looks like a Batmobile for small people Yaris for the next 300,000 miles. Ha. I'm really not complaining, actually. All I really care about is reliability, and we've got it pretty good in that respect with the Yaris.
Nightangel,
Another thing I'd recommend is buying an Ecometer from MicroImage. I eyeball my Ecometer more than my center guage cluster. It's pretty addictive, actually. But in all reality, it helps to control ones fuel consumption in real time. And MicroImage is the cheapest you'll find for the Ecometer, so.....
Old 08-23-2012, 07:13 PM   #15
nookandcrannycar
edmscan,
Nightangel,
Silver was my (unavailable) first choice re my Yaris, as I have found re my past experience that silver cars show dirt the least. However, after moving to SE Texas (after getting my Yaris) my next car and each one after that will be WHITE as long as the manufacturer makes what I want in white. I purchased a BLACK car new back in the 90s with NO A/C. I will NEVER make that mistake again.
Old 08-22-2012, 06:11 PM   #16
schume
Drives: 2010 Yaris LB
Being that you're complaining of 100 degree temps, you must be east of the Cascades :) Your commute is extremely short. Factoring in the other items, 26 is probably about right. You need a lot more miles on your car before you start getting better numbers. I didn't break 40MPG highway until around the 8000 mile mark. Take a few road trips and keep it around 60. :) I need to go to Montana next month, maybe you can drive me? Good excuse to get some break in miles on your car!
schume is offline   Reply With Quote
Old 08-22-2012, 06:38 PM   #17
b20vteg
no show, no go :(
b20vteg's Avatar
Drives: 2012 yaris 3dr hb
i get 40+ going 75-80mph. haven't gone over 80 yet, so not sure about 80 and beyond...
b20vteg is offline   Reply With Quote
Old 08-23-2012, 07:20 PM   #18
nookandcrannycar
Great MPG considering your speed! I think those of us in areas where the metro is pretty flat (Phoenix, Houston, etc) have an easier time getting better MPG. I know personally that it was harder in the San Francisco Bay Area to reach 40 combined. You also have the added advantage of being at a higher elevation than most flat metros.
Save thousands and BIG MPG almost PRIUS jay cobbs New YARIS Purchase Forum 6 08-28-2012 09:38 PM
Why sub-compacts and compacts get almost the same MPG Kal-El Off-topic / Other Cars / Everything else Discussions 0 08-11-2011 12:51 AM
3000 mi Summer Trip Log...MPG included! slothman86 Fuel Economy Forum 14 07-20-2010 01:15 PM
Better MPG in the City vs. Hwy Loren Fuel Economy Forum 21 01-29-2010 12:49 PM
My progression into hypermiling BailOut General Yaris / Vitz Discussion 8 10-13-2009 07:31 PM
