Old 08-31-2010, 03:40 AM   #1
no1trancefan
Drives: Yaris T-Sport
Replacing yaris battery with yellow top
I'm replacing my 02 yaris ts battery, taking the curent 45ah out and putting in a new yellow top, however its only 41ah will that diff in 4 ah make much difference? i am running an amp, i was oging to check it eveyr week on a voltmeter and charge it up to see how it gets on, many thanks
no1trancefan is offline   Reply With Quote
Old 08-31-2010, 09:17 AM   #2
fnkngrv
Mr. 155 and climbing
fnkngrv's Avatar
your first mistaken is buying an Optima battery....they are well overpriced and are no better than other offerings...many times they are worse. Their warranty is horrible to boot.
Old 08-31-2010, 02:47 PM   #3
yarrr
Drives: 07 sedan
I've literally seen 100s of people running optimas with no problem. Do you understand what deep cycle is and why people pay more for these batteries?
yarrr is offline   Reply With Quote
Old 08-31-2010, 11:54 AM   #4
YarisSedan
Drives: 08 Yaris Sedan
Yellow top isnt really made for a starting battery. You would have been better off going with a red top (cheaper also). I think yellow top is best used as a secondary battery for those who have a very high powered stereo system.
Old 08-31-2010, 05:55 PM   #5
sleey0
Drives: 2008 Yaris LB
People pay more for them because it says "optima" on it.
sleey0 is offline   Reply With Quote
Old 08-31-2010, 08:51 PM   #6
ludlamtheory
Drives: 2007 red 2 door
Yellow top vs red top =
deep cycle vs non =
discharing vs cca
So. in English:
A red top is a starting battery, but like most starting batteries, if you discharge it completely too often, the life of your battery is severely impacted.
A yellow top is a deep cycle battery, which can be discharged completely WAY more times without damaging the battery's life.
but
A red top can put out way higher current bursts, or CCA, which is cold cranking amps.
example: In my civic in the days of way back I would often leave the car off but the radio on at shows, meets, etc, so I had a 200 amp relay in my 12v line. ignition off, the amps and headunit would be powered off the rear deep cycle with no fear of not being able to start my car. Up front I had a standard starting battery.
To determine which you need we must first know, why are you replacing said battery with said optima.
Now, one CAN run a yellow top up front, and one CAN use one reliably for along time, but that is not its purpose.
ludlamtheory is offline   Reply With Quote
Old 08-31-2010, 10:20 PM   #7
The Architect
Give Me Resonance
The Architect's Avatar
Drives: 2007 Yaris HB
Im doing it and so long as you know anything about how to maintain an electrical system you'll be alright. I do have an HO Alt so it helps dramatically but if youre going to just replace the battery and call it a day then look into Kinetic.
Also the D35 Yellow top is a 48ah battery not 41. (if you can fit it)
PG TLD22 8V Line Driver
Old 09-01-2010, 09:57 AM   #8
POORSHA
POORSHA's Avatar
Drives: 2008 LB
I put in a yellow top because I deep cycle the batt. My old red top didn't like that very much.
POORSHA is offline   Reply With Quote
Old 09-01-2010, 03:26 PM   #9
wsladaritz
Y4R1Z
wsladaritz's Avatar
Drives: Yaris LB
I put in a yellow top optima because with the stock battery my head lights dimmed considerably when I was jamming music on the highway. I don't have that problem anymore since replacing. I didn't know anything about setting up an electrical system with two batteries back then when I did the swap.
wsladaritz is offline   Reply With Quote
Old 09-28-2010, 12:23 PM   #10
zahirrahman
Drives: yaris 4dr sedan pacific blue
A capacitor would solve the problem of lights dimming.
zahirrahman is offline   Reply With Quote
Old 09-28-2010, 06:53 PM   #11
The Architect
Give Me Resonance
As long as you dont assume like so many others that a capacitor magically means you can add a bigger amp and/or blast your music 5 times harder and all is ok.
Old 09-08-2010, 02:35 PM   #12
redglare45
redglare45's Avatar
Drives: 07 Sedan - 5 Speed Manual
Any pics of your yellow top installed? Looking to see how it's tied down. Did you use the original battery tie-down?
redglare45 is offline   Reply With Quote
Old 09-08-2010, 03:37 PM   #13
sleey0
off topic but does the yaris need a reverse polarity battery?
Reason I ask is because if you look at the OEM one, the posts are in the back.
Most of the aftermarket batteries I have seen pics of have the posts in the front, so if you have to turn the battery around you would need reverse posts. Right or wrong?
Are the pos and neg lead wires long enough to rreach the front of a battery with posts in the front?
Old 09-08-2010, 08:38 PM   #14
wsladaritz
Y4R1Z
wsladaritz's Avatar
Drives: Yaris LB
I'll take a pic for u in the morning in the light... it's not pretty though. I had to get an extension thingy at autozone cause the battery didn't exactly fit in there right. And I don't have a tie down on it right now :( I guess it wasn't tight enough cause a piece of it wasn't there one day. So I took the rest out before it dropped to the road as well. Anyone recommend a good cheap replacement? Cause I probably SHOULD have something holding the battery down.
Old 09-09-2010, 12:52 AM   #15
FcukThis
Drives: yaris
I replaced the original battery yesterday with a generic costco battery..
60 bucks.
The fitment wasn't 100% perfect, (fitment type 3).. The tie down wouldn't secure properly.. I ended up zip tying a little bit of the tiedown to get it nice and snug.. No way in hell that thing will go anywhere.
If I had to do it any other way, i would probably get some ABS plastic, and heat bend it to fit perfectly.. Perhaps you should try that wsladaritz. Take a sheet of abs plastic, heat bend-- then drill some holes accordingly. Go to home depot grab some wingnuts and metal pieces and tighten the abs down.
I don't think very much heat gets all the way to the battery, so you shouldn't worry about the ABS bending.. I actually have several pieces of 3m double sided tape stuck right beside my battery.. None of it has melted off.
FcukThis is offline   Reply With Quote
Old 09-28-2010, 10:34 PM   #16
RedRide
RedRide's Avatar
I had an Optima red top in my Celica that had a custoum sys including a 700w kicker amp.
There was absoluty no light dimming, etc as it has a proper capacitor installed.
After 5 years it was stiil going strong 'till the day I recently sold the Celica
An optima red top has better cold cranking power than the stock. It could be 0 degrees out but it turned over like it was 80 degrees even after sitting outside all night.
Optimas also are completly sealed so, there is absolutly no post corosion problem.
BTW, like most Toyota's the Yaris takes a #35 battery. #35 is an industry designation.
Old 09-29-2010, 12:02 AM   #17
sqcomp
Roadrunner Jr.
sqcomp's Avatar
I wanted to do something a little different than than an Optima:
(you should feel the weight of the hood...I added a layer of Stinger Roadkill Extreme and a layer of Stinger 1/4" Overkill under the stock insulation)
― Thomas Paine
Old 09-30-2010, 11:53 AM   #18
wsladaritz
Y4R1Z
wsladaritz's Avatar
Drives: Yaris LB
That is a beautiful setup sqcomp
**SAFETY RECALL!! 06-07 YARIS HB & SEDANS** slvryaris DIY / Maintenance / Service 83 09-30-2012 12:25 PM
5 Toyota/Scion in TOP 10 MOST ticketed cars - is Yaris next? Yawesh General Yaris / Vitz Discussion 13 03-06-2009 10:39 PM
