SQUEEKY brakes
whenever i release the brake pedal, theres a loud squeek....assuming calipers need lube?
brake shoes needs cleaning.
i do hope you know that when i said brake shoes, i meant rear brakes right ??
![]() Drives: 2008 Yaris sedan Join Date: Jul 2010
My brake shoes rub against the backing plate. What grease can I put on that won't ruin my brakes?? Thanks!
![]() ![]() Drives: Yaris Sedan Join Date: Apr 2012
You can try some anti-seize where the shoes touches the backing plate. Just a fine layer...
![]() ![]() Drives: 07 hatchback Join Date: May 2012
or there is brake grease that they sell in the autoparts stores
Assuming the squeak is from the rear (and it should do so when e-brake is pulled/released too):
Use a screw driver to gently pry the shoes away from the backing plate and apply a thin layer of anti-seize to the 3 spots that shoes touch the backing plate. Clean most of the dust out, and adjust brakes. Chances are if it's moving enough to make noise, you are way out of adjustment. If you were to sand the shoes, and remove the sharp edges, you have just completed a "rear brake service and adjust" and you can charge yourself about $50 ![]() Cheers. |
| A few questions about suspension, tires, and brakes. | supmet | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 10 | 02-02-2009 04:55 PM |
| Weird question about my brakes | brainless twit | General Yaris / Vitz Discussion | 8 | 01-22-2009 10:59 AM |
| Brakes | Geelmeel | General Yaris / Vitz Discussion | 16 | 06-29-2007 07:58 PM |
| Brakes question | MeggiemobileSFLA | DIY / Maintenance / Service | 23 | 03-16-2007 05:17 PM |
| Changing drum brakes to discs? | eTiMaGo | Performance Modifications | 5 | 09-25-2006 04:17 PM |
