Old 10-10-2012, 03:48 PM   #1
Krazzyd
Drives: toyota vitz 06
2006 toyota vitz low trackling PROBLEM
HI I HAV A 2006 VITZ HATCHBACK I TOOK OUT THE BATTERY WHEN I PUT IT BAK IN THE CAR STARTS TRACKLING LOW AND SHUTS OFF...NEED HELP ASAP PLEASE THANKS
Krazzyd is offline   Reply With Quote
Old 10-10-2012, 04:19 PM   #2
That is normal after unplugging the battery for a bit. If it doesn't clear up after running it for a little while, then you may need to clean the throttle body.
Old 10-11-2012, 06:59 AM   #3
Krazzyd
HOW LONG SHOULD I RUN IT FOR?
Old 10-11-2012, 08:11 AM   #4
By the end of a 5 minute drive it should be OK. If not, then I would clean the throttle body.
Old 10-10-2012, 04:55 PM   #5
Kens
RS
Kens's Avatar
Drives: Toyota vitz rs 2006
I have had this problem when I replaced my battery. I ran it for 2 weeks and the problem persisted. I then checked the screen display which is a carrozzeria, all in Japanese and went into the settings. I put everything on ON and the problem went away. I too have a 2006 one so if you have the same screen display as me, try it out.
Kens is offline   Reply With Quote
Old 10-11-2012, 07:00 AM   #6
Krazzyd
DONT HAVE A SCREEN DISPLAY
My Ride Toyota Vitz 2006 1.0 vvt-i ajjubravo Cosmetic Modifications (Exterior/Interior) 17 11-09-2012 11:50 PM
06-10 Yaris Sedan cold air intake $40 kylevh21 Items for Sale by private party 2 04-01-2012 02:14 PM
2006 Toyota Yaris - Perth WA [For Sale] ruimond Australia 4 01-30-2011 03:41 AM
Toyota Vitz 2006 automatic - engine revs lot thea500 General Yaris / Vitz Discussion 0 11-24-2010 02:05 PM
