![]() Drives: 2008 yaris Join Date: Oct 2012
speedometer backlight
Hi; The backlight on a 2008 yaris doesn´t come on when the lights are off. any help is appreciated. Thanks
Which instrument cluster do you have (speedo only, speedo with tach, MPH, kmh)? The reason I as is that some of the clusters I have experimented with have the backlighting without the headlights and others do not.
Speedo backlight
Hi; It has the tach and km. The backlight came on with lights off. Not anymore
Check the 7.5A MET fuse in the fuse panel that is under the bottom of the dashboard on the drivers side.
Thanks!! I´ll try that tomorrow morning
Tried all 7.5 amp fuses. All 0k, still no light. What else?
The 7.5A MET fuse should be the one driving that, but also check the 10A GAUGE fuse and 10A ECU-IG,
YARIS SPEEDO BACKLIGHT
Hi CT; Checked all, still no go. Could it be the light dimmer on the dashboard? Would you know of a diagram for it? It seems easy to pull out but not to disconnect.
I don't believe the dimmer rheostat is the issue, since it is only used by the cluster when then headlights are on (and in that mode your backlight works).
The wiring diagrams are downloadable from the Micro Image forum (http://www.microimageonline.com/foru...32-YARIS-FILES) Do you have a multimeter?
Yes I have a multi tester. It´s a bear to use under the dash!! I´ll be downloading the schematic later on todau. I appreciate your help.
#11 | |
Specifically, on the right side connector, check the black wire on the top right for 12 V (the brown on the bottom left is ground). Also check the blue next to the black for 12 V as well. Also, measure the voltage on the grey and yellow wires with the headlight switch both on and off. Those two wires are the input to the cluster from the dimmer rheostat.
| Speedometer Accuracy? | YarisPete | DIY / Maintenance / Service | 37 | 11-29-2013 02:00 PM |
| Speedometer Calibration / DeMetrification | CTScott | DIY / Maintenance / Service | 17 | 10-06-2012 09:00 PM |
| OEM Speedometer with tachomter | Deshi Basara | DIY / Maintenance / Service | 6 | 08-21-2012 10:11 PM |
| speedometer | walt101786 | Cosmetic Modifications (Exterior/Interior) | 0 | 10-09-2010 09:03 PM |
| No speedometer or tachometer lights during day | cdavidhess | DIY / Maintenance / Service | 20 | 06-30-2009 10:38 AM |
