Old 03-07-2007, 10:25 PM   #1
nurburgring
ringmeister
nurburgring's Avatar
Drives: YARIS 1.5
205/50R16s alright for a yaris ?
Hi Guys,
My new black yaris 1.5 5 dr is coming next week. I'll be slapping on some rims and lowering with TRD springs.
I want some 16" wheels, porbably a Advan RGII replica.
My concerns will be noise and wheel/fender rubbing.
WHat offset should I be going for if I do not want an rubbing at all ?
I'm also torn between going for 205/50R16 tyres or 195/50R16. The 205 are large , so it should fill the wheel arch abit more, but will they rub ? Its almost 20mm wider, and 0.4 of an inch larger in diameter. 205/50R16 is actually smaller than some rides who put 205/45R17.
It shld look pretty trick. Still deciding the colour of the rims too. I was thinking bronze, but bronze would look a little dark on a black car. But Silver would be too ordinary it seems.Maybe white ?
nurburgring is offline   Reply With Quote
Old 03-07-2007, 10:34 PM   #2
Black Yaris
der Zeck
Black Yaris's Avatar
Originally Posted by nurburgring View Post
Hi Guys,
http://www.1010tires.com/TireSizeCal...bmit&reset=yes
here this should solve all your tire questions
I am running 225/50R15's with no rub... so you can go wide with no problems, just get the correct offset for the width... a 7 inch wide wheel should have a +38 offset
Old 03-08-2007, 05:35 AM   #3
nurburgring
ringmeister
Drives: YARIS 1.5
For 16 inch wheels and 205mm tyres, what offset and what rim width shld I go for ? I do not want an over stretch look.
Old 03-08-2007, 12:18 PM   #4
SailDesign
Drives: .
I'm running 205/45-16s with a 42 offset, no rubbing. Pics in my garage.
Old 03-08-2007, 04:59 PM   #5
jdubau55
Drives: 2007 White Yaris LB 5 Spd.
Send a message via AIM to jdubau55 Send a message via Yahoo to jdubau55
I think when I was running my calculations that this was this best size for a 16" wheel. At least this is what I plan on getting for when I get 16's.
jdubau55 is offline   Reply With Quote
Old 03-08-2007, 05:14 PM   #6
largeorangefont
Break'em off some.
largeorangefont's Avatar
Drives: 07 Yaris LB, 04 Cobra
I have 205 50 16s on 16X7 +40mm offset. Check out my garage for pics. They work and look great.
This is the size that is closest to the stock diameter.
Old 03-08-2007, 07:03 PM   #7
SailDesign
Drives: .
True, but I wanted to go a bit smaller (by 0.5") and the 50s are bigger by 0.3". The biggest difference, apart from your speedo reading low while mine reads high, is that you get a marginally better ride than I do. Main thing is that we're both happy with the choice
Steve
Old 03-08-2007, 08:44 PM   #8
largeorangefont
Break'em off some.
Steve
I like the way the 50 series filled out the wheelwells better, but it is all personal preference.
Old 03-08-2007, 07:05 PM   #9
cleong
Parallel Parking Pro
cleong's Avatar
Drives: Yaris 1.5 Manual
205s will increase road noise, drag, and fuel consumption over 195s. You will get more mechanical grip, which is always helpful if you like going around bends quickly.
cleong is offline   Reply With Quote
I test drove a Yaris, Versa and FIT CanadaCraig New YARIS Purchase Forum 41 11-29-2008 09:18 PM
Toyota Yaris to Sponsor FOX's "Prison Break" YarisBueller General Yaris / Vitz Discussion 0 04-30-2006 08:01 PM
