![]() Drives: 2010 Yaris 5-dr auto Join Date: Jul 2010
is 5000 miles too long to wait for an oil change?
Why does Toyota recommend a conventional oil change at 5000 miles for the Yaris? Every other car I've owned required a conventional oil change at 3000 miles (or 5000 if synthetic).
![]() Drives: 2008 Yaris Sedan Join Date: May 2010
I think the 3000 mile interval is for Super Lube to make more money. A car that is driven in normal conditions does not need that frequent of an oil change. If you drive at high speeds, or pull a trailer then the interval should be reduced. The Dodge Ram truck owners manual goes into detail about this because trucks tend to pull heavy weight, etc. The oil change light on my car comes on at about 4500 miles, and the oil still looks fairly clear; the level is still at the full mark. I just checked the valve clearances at 82,000 miles and they are all still within spec, so there does not appear to be any noticeable engine wear. Valve cover pretty clean, almost like a motorcycle engine in there it was so clean. I have a MT '08 Sedan w/TRD suspension, it gets driven pretty hard on the twisties about twice a month including a couple of jumps, I run about 77 mph on the interstate for 400 miles per week, redline the engine frequently.
So in a short answer, no 5000 miles is not too long for a Yaris, especially driven like most people drive. The car appears to have very good blowby control; very little contaminants get into the oil.
![]() ![]() ![]() ![]() ![]() Drives: 2008 Toyota Yaris Liftback Join Date: Oct 2008
I change mine every 7500 miles with fully synthetic oil. No problems!
C-Lift ![]() -------------------------------------------------------------- Current Mods: MI Armrest; Full LED conversion (interior and exterior); RS spoiler; Tinted windows; Tanabe DF210 lowering springs; aftermarket door speakers; 12" RF P3 subwoofer with custom box wrapped in Neffy; seat covers; HID 8000K headlights; HID 3000K foglights; 13mm PG hub spacers; muffler delete with dual tip; eyelids; and.. A little red Domo mascot!
I dont think that is a problem, I allways change mine to 5000 to 6000 and my car has 58789 miles and with no problems at all.
Modded Moderator
That's "old school" thinking. Following toyotas recommended oil change interval is just fine.
no problem with a good 5w-30 conventional oil such PENNZOIL ( now rated SN ) , HALVOLINE , etc..
#8 | |
Drives: '10 Yaris5drHB+99 4runner LTD Join Date: Sep 2009
3000 miles change is an old recommendation when engines and oil formulas were built to less exacting standards. that crap doesn't apply anymore, but oil change places put the fear into you so they make more loot follow the owners manual. if you use mobil 1 go to 10,000 miles before oil change |
This.
Oil is a precious and limited natural resource, and people are pouring it away because of some outdated information. Luckily some of it can be recycled, but it would be better to use it to its maximum extent than to needlessly change it because of ignorance!
Steals terrorist's lunch
Drives: 2007 Yaris Liftback Join Date: Mar 2007
Well said! And there are "extended performance" blends out there that let you go all the way to 15k miles between drain intervals. I've been doing this along with a high performance filter since the first change and things are running fine at 65k miles. I have yet to find any metal on the magnetic drain plug.
- Brian Share the Road I often carry 2 carpool passengers and mountain bikes or snowboards/skis over a 4,500 foot elevation difference. Click the graphic above to see my detailed mileage logs. |
"Gettin Jiggy wit it"
5000 mile oil change
5000 miles on an oil change, it depends on how much you love your car. Yes todays engines are better built then long ago, I was a mechanic then and still am. I also worked in an oil testing facility in the military. There is more break down of the oil the longer you use it, except synthetic oil. Toyota does not make any money from you by having engines last 500,000 miles. They want the engines to wear out sooner so they make more money. I did my first oil change on my "S" liftback at 1800 miles and my routine oil changes are at 2500 miles. Oil is cheap,engine work is not. Yes, you believe what you want to. Our 1.5 is a small motor that works hard and makes alot of heat. I have tested oil for many engines in a lab environment. Its science, not speculation.
#12 | |
Drives: 07 sedan Join Date: Mar 2010
![]() ![]() Drives: 07 Yaris Sdn, 97 4Runner Join Date: Jul 2006
Use Amsoil and go 15k miles.
![]() ![]() Drives: 07 Yaris Sedan Join Date: Jan 2009
I think it depends which filter you use.
Fram Tough Guard has a change interval of 7500 miles. I use this one. http://www.fram.com/oil-filters/tough-guard.php Fram Xtended Guard has a change interval of 10000 miles. http://www.fram.com/oil-filters/xtended-guard.php |
Thread locked in 3, 2, 1......
If you want to enjoy your car, stay off of the internet. |
#17 | |
Auto manufactures want to claim that their cars are more maintainence free and "greener" than the competition. Bottom line, it's your car, you are paying for it so, change the oil when you want to. Personally, I change my oil about every 3k miles or so.
#18 | |
![]() ![]() Drives: 2009 Yaris Join Date: May 2010
| best synthetic oil and m/t oil?? | doodoo | DIY / Maintenance / Service | 122 | 04-03-2017 08:43 PM |
| Dealer oil change | boggydee | DIY / Maintenance / Service | 16 | 06-30-2010 11:21 PM |
| Oil change time... yay! | YarisFan007 | DIY / Maintenance / Service | 10 | 09-19-2007 05:40 AM |
| Dealership wants $64.99 for Oil Change? | ScottFern | DIY / Maintenance / Service | 15 | 09-21-2006 10:49 AM |
| Oil change question | Ryu | DIY / Maintenance / Service | 22 | 03-07-2006 11:21 PM |
