Old 01-04-2017, 12:36 PM   #1
fredovvti
Drives: Yaris 07 HB
Problems with OEM Lock Switch
Hi,
Recently I buy a OEM lock switch for ma yaris a 2007 hatchback. The car have the factory locking system, the only thing that a miss is the switch in the center console. The Problems I install the switch and nothing happen. No lock/unlock the doors. What that i miss! Any help please!
fredovvti is offline   Reply With Quote
Old 01-06-2017, 06:04 PM   #2
Motzking1
Motzking1's Avatar
Drives: 47 2013 yaris l hatchbacks
Lock switch? Can you expand on that? The lock cylinder in the door? The power door lock driver? Why did you replace it's part. What was the problem before you replaced part xxxx?
Sent from my SAMSUNG-SM-N900A using Tapatalk
Motzking1 is offline   Reply With Quote
Old 01-06-2017, 09:29 PM   #3
fredovvti
Drives: Yaris 07 HB
This little thin.
Old 01-07-2017, 03:31 PM   #4
Fuse?
Try looking at fuse#39 in the under dash fuse box.
Old 01-07-2017, 03:41 PM   #5
Motzking1
Motzking1's Avatar
I'm still a bit confused on your post. Was the system intact and working at one point?
Old 01-08-2017, 06:07 AM   #6
IllusionX
Drives: 07 Yaris Sedan Aero
If you didn't have the switch in the console (hatchback), then you do not have a factory system.
What tells you have factory powered door locks?
Sent from my SM-G930W8 using Tapatalk
Old 01-08-2017, 10:11 AM   #7
fredovvti
Drives: Yaris 07 HB
Because in the doors come withs this with plugs:
And in the rear hatch come with one too
Old 01-10-2017, 12:05 PM   #8
Motzking1
Motzking1's Avatar
Because that is in the door and trunk does not mean it was installed, oe, or at any time working. Copy down your vin number and go to your local toyota dealer parts department and ask them if that vin came with factory locks or not. If you can't get info from them try searching a vin decoder in the forums. I'm sure you will find some posts to a good one that can provide the info. Also if you have the origonal sticker that came with the car that will help. It would be listed as an option there. If for some reason you exhaust all those options first let me know. I will get a wiring diagram and component located and help you.
DIY - OEM Power Window Conversion CTScott DIY / Maintenance / Service 29 10-28-2024 12:02 AM
Doors Won't Lock TutorMe DIY / Maintenance / Service 3 08-05-2014 04:04 PM
Ultimate yaris part out, aftermarket and OEM yaris rs Items for Sale by private party 25 06-20-2011 01:43 PM
how can I add a power lock switch? gabriel2012 DIY / Maintenance / Service 10 01-01-2011 09:08 PM
OEM Parts hatchbackkid82 Items for Sale by private party 30 12-17-2009 11:08 AM
