Old 11-08-2012, 09:09 PM   #1
BruceLee
BruceLee's Avatar
Drives: 2008 Yaris Hatchback
Philips DRL Flicker Issue
After reading some post, I have followed the basic instruction of wiring the fog light like the following, but here comes the LED blinking issue.
Could anybody tell me where am I wrong?
For the switch, instead of connection with the ignition fuse as the first photos shows, I connect my switch to the "CONSTANT POWER" place shown in the second photos... everthing else remains the same as the first photos
BruceLee is offline   Reply With Quote
Old 11-08-2012, 09:11 PM   #2
BruceLee
BruceLee's Avatar
Oh, btw, I did not use the OEM switch, just an aftermaket switch, and I dont need the indicator lights up on the dashboard...
Old 11-09-2012, 12:05 AM   #3
yarisugi
やりすぎだ~
yarisugi's Avatar
Drives: Me: Nuts:
Why do you have a SPDT relay there? (Bosch relay)
Wouldn't it be better to have a SPST relay?
Old 11-09-2012, 12:16 AM   #4
BruceLee
BruceLee's Avatar
forgot to mention that, yes, I use SPST, do I miss something and lead to that blinking issue?
Old 11-09-2012, 07:03 AM   #5
The relay type doesn't matter. With a SPDT, you just aren't using the second pole.
Where did you connect the power wire for the actual fogs? Are they connected to the battery, or did you connect them to the headlight power wire?
Old 11-09-2012, 11:44 AM   #6
BruceLee
BruceLee's Avatar
Hi, Scott, Yes, on spst relay, "30" to the battey with 5Amp fuse, "87" connected with two fog light positive wire.
Old 11-09-2012, 01:38 PM   #7
In that case, you may just have a bad set of LED fogs. I would take the fog lamps and try powering them directly from the battery, without a switch or relay in between, to see if they still have the same issue.
Old 11-09-2012, 02:56 PM   #8
BruceLee
BruceLee's Avatar
Before I test it by directly connecting to battery, here is what I just did.
I let my friend drive my car and I noticed that when the engine is idle, say waiting in front of stop sign, the led is blinking; next when reversing the car out from a parking lot, at that speed, the LED is blinking as well; But while driving OR the car is put into "P" position (my car is an AT), the LED fog is fine.
the LED FOG light is set of Philips Daylight 4, I did not use the module came with the box :)
Old 11-09-2012, 02:59 PM   #9
OK, I let my friend drive my car and I noticed that when the engine is idle, say waiting in front of stop sign, the led is blink;
next when reverse the car out from a parking lot, at that speed, the LED is blinking as well;
(the LED FOG light is set of Philips Daylight 4, I did not use the module came with the box)
It may be that the voltage is too low, until the alternator starts outputting more with the car in motion, but again I would try connecting it directly to the battery to see if they still flash.
Old 11-29-2012, 09:56 PM   #10
BruceLee
BruceLee's Avatar
Forget to reply earlier, sorry, been through my busy final at the end of semester
I discarded the relay, and simply connected it with the switch to the battery, without control box...
and, sad, the flicker continued while in low RPM, I will update later after I install the control box...
and Thanks a lot, Scott
Old 11-29-2012, 10:51 PM   #11
yarisugi
やりすぎだ~
yarisugi's Avatar
Drives: Me: Nuts:
Does your car have factory DRLs? In the instructions, Philips states you must disable it before you hook it up or get their compatibility kit. Philips is quite reputable so I don't foresee any faults from the kit. Attached instructions.
Old 11-29-2012, 11:08 PM   #12
BruceLee
BruceLee's Avatar
Ahh.... almost forget that, thanks!!! do you know I could just unplug that DRL relay to "disable" it as the following thread said?
http://www.yarisworld.com/forums/showthread.php?t=894
Old 11-30-2012, 11:47 PM   #13
screenprintr
screenprintr's Avatar
Drives: 2010 Toyota Yaris
I'm sure glad you asked the question. I'm planning on installing Fog lights. Now I know where the DRL is incase I need to disconnect them.
screenprintr is offline   Reply With Quote
Old 12-01-2012, 06:47 AM   #14
He is not connecting the fogs to the headlight output, so the DRL module has nothing to do with the issue (nor with installing non-LED fogs).
As mentioned in post #14 above, he installed them without using the module that Philllips included for driving them, so I suspect that the flashing is due to that.
Old 12-01-2012, 07:25 AM   #15
ciscobear
Drives: Toyota Belta
I am still lost as to why he isn't using the control box that's included in the kit....why complicate matters?
ciscobear is offline   Reply With Quote
Old 12-01-2012, 09:37 AM   #16
BruceLee
BruceLee's Avatar
Smile PROBLEM SOLVED
My fault, the reason I did not use the control box is the intruction says I have to disable Yaris factory DRL first before install, and previously I have no idea how to correctly disable it (I not sure if I can just disconnect the relay)...
NEW UPDATE: the flicker issue is GONE! SCOTT is right! and I don't even disable the DRL, just install the control box, voila~
Go Wangan Style !
Old 12-01-2012, 09:41 PM   #17
screenprintr
Good for you BruceLee. Nice job.
Rear fog / reverse light question bechdan DIY / Maintenance / Service 1 02-12-2012 01:01 PM
Fog light jumping question netz2008 DIY / Maintenance / Service 1 01-16-2012 09:55 PM
LED'n it out (warning...big pics) custom Lftback Photo-Video-Media Gallery 9 05-24-2010 03:41 AM
rear fog light and tuned rear lights lefti696 Cosmetic Modifications (Exterior/Interior) 0 11-09-2006 03:06 PM
blinking LED light kaymm In Car Entertainment + Electronics (audio / video / alarm) 3 09-14-2006 10:05 PM
