Old 10-20-2011, 04:48 PM   #1
LouUKUS
Drives: 2007 Toyota Yaris
Radio Reception after Car Detailing
Hello everyone,
I am a newbie wondered if I might be so bold as to ask a question?
I had my 2007 Yaris detailed last week after some bodywork was done. When I picked it up the saved radio stations were lost (which is fine) but the reception is now scratchy on stations that were previously clear.
Any suggestions as to what I should be checking?
Many thanks in advance folks - it's appreciated.
Lou
LouUKUS is offline   Reply With Quote
Old 10-20-2011, 05:15 PM   #2
Klink10
Klink10's Avatar
Wouldn't surprise me if the detailer took the ant. off to do the work. Ck that.
Old 10-20-2011, 05:26 PM   #3
Do you have a sedan or liftback? The sedan's radio is built into the rear window, so if interior detailing was done, the cable that connects to the glass may have been ripped loose. If it is a lift back, like Klink mentioned, check to see that the antenna is still up top.
Also, was the dash taken apart at all?
Old 10-20-2011, 06:05 PM   #4
Revsson
CTScott meant to say that the sedan's radio antenna is built into the
rear window. But you probably figured that out.
If you lost the saved radio stations, does that mean that they
disconnected the battery? Did the body work require that they remove the battery?
What kind of body work was done to your car? Was the radio working properly
after the body work and before the detailing, or was the detailing just after
they did the body work?
If you look at this section from the factory repair manual, you will see the
route that the antenna cabling takes.
http://www.etimago.com/yaris/repairm...o%20Visual.pdf
Just wondering if the body work was done on the areas that the cabling
is running through?
Perhaps you can give us more information?
Old 10-21-2011, 09:45 AM   #5
LouUKUS
Firstly - thank you all for your replies so far.
Secondly - more detail.
I have a 4 door sedan. I guess they could have damaged the wire when cleaning the rear window? I will certainly take a look at the wiring to the antenna and see if there is anything obvious wrong.
Bodywork involved new bumper (after being rear-ended) and work on a rather large scratch on the front passenger door (Yaris vs. concrete pillar in parking garage)
My saved radio stations were no longer saved - this led me to believe they may have disconnected the battery for some reason. I am by no means any kind of expert - so I have no idea why they might disconnect the battery.
The bodywork and detail were done at the same place at the same time - so I don't know when the radio station problem begain - I just know it was like that when I picked it up.
Thanks again everyone.
Old 10-21-2011, 09:59 AM   #6
_S7V7N_
_S7V7N_'s Avatar
Drives: Yaris 4 Door Sedan
Do you have the Integrated Radio or the regular one that comes in the majority of the yaris, take a pic of it. UP close shot as well so we can pull the model number and possibly do a quick Google search and possible trouble shooting techniques.
Check your ground cable to your battery, Maybe they didn't tighten it down ?
Old 10-21-2011, 06:26 PM   #7
BLH
Drives: 2007 Yaris Sedan
MickZEL; Some countries like the US only use frequencies ending in the odd numbers.
If your radio was designed for one of those countries. All the even ending numbers will not be avilable.
Looks like CTScott may have the answer you needed.
BLH is offline   Reply With Quote
Old 10-26-2011, 01:51 PM   #8
LouUKUS
Ok, developments:
- Took a look at the antenna in the window - couldn't see anything amiss
- Discovered that if I turn the rear window heater off the reception is fine
Weird - but solves the problem I guess (unless the rear window needs heating!)
So - live with it like it is, or keep investigating?
Old 10-26-2011, 02:08 PM   #9
Originally Posted by LouUKUS View Post
Ok, developments:
There is a noise filter behind the left C-pillar that is supposed to suppress the electrical interference from the defogger to the antenna. It may be disconnected or bad.
Old 11-08-2011, 01:36 PM   #10
LouUKUS
Ok cool - I'll investigate further.
Thanks again for your help.
Old 01-04-2013, 11:51 PM   #11
gee69off
Drives: 07 Yaris S Sedan
please....help!
This is my first post but this exact thing happened to me. My radio is fuzzy as hell and when I turn the defroster off its crystal clear. I'm a dumbshit when it comes to cars, so please excuse me, hopefully ill be learning more soon. Where and what exactly is the C-pillar? Lol and being every part in a car illiterate, how am I going to locate this noise filter? Help the yaris handicapped...
On another note, CTScott, its members like you that made me join this site. There are so many cool projects with great instructions from members like you, and you're incredible knowledge and your willingness to share that knowledge make this such an incredibly awesome tool to me learning about my car! Keep it up and thank you!
gee69off is offline   Reply With Quote
Old 01-05-2013, 07:16 AM   #12
The C pillar is the rear most vertical support for the roof. Pop off the plastic cover between the rear driver's side window and the back window and you will see a black plastic chunk about 1"x1"x1" with a connector plugged into it.
Old 01-05-2013, 06:52 AM   #13
bronsin
bronsin's Avatar
Awesome display of technical knowledge and assistance!
The internet moght be good for something after all.
My advice?
Turn the window defroster on or off to get radio reception and leave it at that.
Old 01-05-2013, 07:41 PM   #14
gee69off
Thank you, exactly the kind of direction I need! That's what I thought, but id look more stupid assuming something and being wrong than asking. Ill give it a look tomorrow after this snow stops!
radio, scratchy
Car Buying Scams nemelek Off-topic / Other Cars / Everything else Discussions 1 09-29-2011 08:01 PM
KCALB SIRAY - Photo Scavenger Hunt KCALB SIRAY Photo-Video-Media Gallery 5 03-02-2009 10:44 AM
Custom Lftback - Photo-Scavenger Hunt custom Lftback Photo-Video-Media Gallery 2 03-01-2009 11:12 PM
Darb - Photo Scavenger Hunt Darb Photo-Video-Media Gallery 3 03-01-2009 09:02 PM
