Old 01-03-2013, 05:04 AM   #1
Conrod
Drives: 2012 Yaris YR Hatch
Cruise control and front bumber
Hello Yaris World friends, I just purchased a new 2012 YR hatch auto and very happy with it. I have two questions you may be able to help me with. I would like to put cruise control on it and understand that most of the hardware is in place and I just need the stalk control. Here in down under Toyota spares wont sell you the bits, you have to take to them and shell out $500 plus for them to install. Does any one know where to get genuine cruise control parts.
Q2 . I only had it for a couple of days and backed out of the mates driveway and scraped the bottom of the front bumper You can not see the damage unless you look under but it still hurts and I will proberbly get it repaired. I will avoid bad driveways now but is there anything you can get to protect the bumper underside.
Thanks in advance
Conrod is offline   Reply With Quote
Old 01-03-2013, 08:00 AM   #2
I sell the cruise control stalk with its harness and mounting screws for $40. Shipping to Australia would only add about $10 to that.
Old 01-03-2013, 09:40 AM   #3
BEEF
BEEF's Avatar
Drives: 2008 yaris 3d
An idea for the underside of your bumper (I have thought about this myself) is spray on bedliner material. This may be different in the US than in Australia but you can get it at an autoparts store in a spray can (like spray paint). Just put your car on ramps, clean the bumper, tape off the part you don't want covered, and spray. I was thinking this could also cover what has already been damaged and it is easy to touch up if it does happen again.
there again, just an idea I have been playing with.
Old 01-03-2013, 05:00 PM   #4
Conrod
Thanks for replys, I will proberly get the scrape marks repaired this time and if it happens again I will consider your idea Beef. I did find a Ebay merchant selling what is called EZlip available in the US. It is a stick on type rubber but it looks a little thick to me which would reduce your ground clearance even moore and I think you would get road grit gathering in between the rubber and the bumber.
Old 01-06-2013, 09:23 AM   #5
stuart_f
Drives: Yaris TR 1.33CVT
I'm not 100% on which bit of the bumper is damaged but would the cheap lip in this thread cover the issue up?
stuart_f is offline   Reply With Quote
Old 01-07-2013, 04:14 AM   #6
Conrod
Thanks Stuart, yeh it would cover it up but I would still know it was there and it bugs me because it is brand new. I plan to see the panel repair blokes in the next few weeks and get a quote. I would take the bumper off myself and take it in and not the car. I could not stand leaving a new car at a panel shop where they leave your window down and the car fills with bog dust from sanding and then they give it back to you with bog dust and some extra scratches thrown in
ABS and "!" lights are ON again! onizuka Canada 457 04-28-2023 10:40 AM
2012 Nissan Versa Kal-El Off-topic / Other Cars / Everything else Discussions 22 06-15-2012 05:48 PM
2012 Camry Kal-El Off-topic / Other Cars / Everything else Discussions 26 10-02-2011 10:20 PM
DIY front control arms special_k_828 DIY / Maintenance / Service 2 04-19-2011 11:31 PM
Newly refreshed 2011 Toyota Corolla Kal-El Off-topic / Other Cars / Everything else Discussions 23 11-27-2010 01:57 PM
