rarer than JDM -1 of 1!
TWM Short shifter install= OWNED
O.K. After disassembling the plastic center console and removing like 15-20 or so screws, I am able to get to the shifter assembly. I remove shifter link cables, then i am stuck trying to pry off the black clip. Without a dremel on hand, i could not for the life of me remove it. I was effing up the white plastic casing pretty well though. It's step 8 on the instruction manual, i can post the pic.
http://www.twmperformance.com/manual...p%20Manual.pdf Just thought i'd share. I'll have to reconvene this project when i can either borrow a dremel, or get to the store and pick it up later this month. Any tips you guys had without using a dremel would help. Otherwise imma blast this bitch off with the dremel! |
Bump for 58 reply-less views!
if I recall how the guys at the workshop installed mine, they put the stock stick in a vise, and yanked at that part with some pliers...
Those clips can be buggers. Definitely designed for easy install and no removal.
If you have a sharp chisel you might get behind it. Otherwise the dremel is a solution. Just be careful not to melt that white plastic assembly while grinding away at the clip. I might try a hacksaw first. Less heat.
I used to have 1700 posts
if i recall i used a flat head screw driver to pry that off just like the picture depicts. i do remember cutting the shit out of my finger in the process when the screw driver slipped out but i got it off with a flat head screw driver.
good luck |
flat head screw driver = dangerous. don't let it slip.
but indeed, people here in Quebec do it with just a flat head screw driver. Seriously, i have no idea how they mange to do so. |
I tried the thinnest flathead screwdriver i could find. After blood, sweat, and swearing (no tears), i gave up. I think a hacksaw could be seriously dangerous. I'll update when i get a chance to do this again, hopefully this weekend.
Mr. Clean
Is this the part you're talking about? Have you tried twisting the screwdriver rather than prying at it?
^^ yeah that's the part. No, oddly i didn't try that, although i must say that i could not fit the screwdriver between the plastic and the clip. I'll give it a shot next week, i'll have a garage to borrow for a few weeks if i need to down my car for any reason. thanks!
やりすぎだ~
if you need a dremel, let me know.
^^Thanks, i just went to lowe's on saturday and bought one. Figured it would come in handy down the road.
OK, installation of short shifter and shift knob complete. The dremel came in most handy, and i didn't have a press, so i bought those clamp type table vise.
Do not get this type. It is rubbish! You can heat the rubber clip w/ a hairdryer and get the thing off. After the dremel and hairdryer, putting it all back took me minutes!! I also installed a cabin bar (called a room bar by ultra), some H.D. endlinks, and camber bolts. All in all, a pretty ok weekend. I need an impact to install my coilovers though, so i got owned again. |
![]() ![]() ![]() Drives: ings 09 Yaris 3 Door LiftBack Join Date: Mar 2009
Is the TWM Short shifter shorter than the OEM shifter in length? Anyone can show me the pic of both side by side?
REAL JDM ings+1 Full Body Kit…REAL JDM C-One Spoiler…Retrofit Projector Headlight…Kiddo 6-pots BBK…CE 28N J-Time Attack…Bride Ergo II Racing Seat…Personal Steering Wheel…Work Bell Quick Release…Dealer Option Sun Roof…JDM RS LED Side Mirror…JDM RS Taillight…C-One Oil Cap…C-One Radiator Cap…TRD Iridium Racing Spark Plug…Tom's Fuel Map Controller…Blitz throttle controller…GReddy Informeter Touch…MR Suspension…TRD Rear Sway Bar…MR C-Pillar Bar…GTspec Front Strut Bar & Rear Strut Bar…AFE Intake…WR Header…Nitto Mid-Pipe…Greddy Ti-C axleback…Goodridge SS Brake Line… To do: Supercharger… |
![]() ![]() ![]() ![]() Drives: 2009 Yaris Hatchback Join Date: Feb 2009
Slowy getting there
It's nice to see you got it installed!
| Save $20 on every TWM Performance short shifter/shift knob combo! | TWM Performance | TWM Performance | 4 | 05-29-2009 04:36 PM |
| twm short shifter installed! | dngz | Performance Modifications | 115 | 08-02-2007 01:11 PM |
| Got my TWM Short Shifter but... | Katana | Performance Modifications | 16 | 01-24-2007 12:42 PM |
| TWM Short Shifter Boxing Week Blowout! | TWM Performance | Sponsors Classifieds Area | 2 | 01-08-2007 04:01 PM |
| TWM Yaris Short Shifter Sale! | TWM Performance | Sponsors Classifieds Area | 9 | 08-28-2006 03:37 PM |
