![]() Drives: Yaris 2010 Join Date: Dec 2011
grounding kit in 2012
i was wondering if anyone still installing grounding wire in 2012?
i saw several HKS kits for 25$ shipped on ebay, is it good for my 2010 LB yaris? will it improve the sparks and acceleration my yaris? suggestion and comments please thanks alot !! |
![]() Drives: yaris sedan 2009 Join Date: Jun 2010
Yes it does help with the performance especially when you have hid kits installed I have to burn a ballast and two bulbs before I put one on I guess toyotas have issues with circulating electricity around. :)
And btw it will also give you good mileage on your car
i have my hid's installed, so should i unplug them first before i ground wire the engine?
thanks alot for your time brieghne |
![]() Drives: toyota yaris sedan 2010 Join Date: Jul 2012
grounding kit
yes it help keeping the car to run smoothly if there's a proper grounding for the car. also check also all ground points for any loose bolts.
![]() ![]() ![]() Drives: 08Yaris2D, 88LandCruiser. Join Date: Jan 2013
I did not feel this was 100% necessary, but I thought it cant hurt, so why not. So I went into my box of odds and ends wires, found some nice 10 gauge and went to town!
Well its funny, but the car is smoother. I'm sold! But I would not waste money on a goofy looking kit, when a handful of wire and some loops will run you less than $5. Here's mine. It starts at the battery ground, then to the CPU, then right side tower(because of the available treaded hole), then a wire into the cab, to the crash bar, and one to the alt mount. |
That's pretty cool -- if you're going to do one, it is pretty easy to make. I think the kits look a little prettier, but your DIY way is far cheaper than what we sell.
If I can make my own for around $15 bucks I will do it. I get static shock from time to time, and my idle goes down when I roll my window down or up, plus running a (small) 400w amp. I'm sure extra grounding should help me out some how. LOL
Got 12ft of 8 gauge wire that's heat resistant, and gasoline/oil proof, and 10 gold plated ring terminals for about $15. So gonna ground some points tomorrow.
| FS: OEM Toyota Vios Turbo Kit | CTScott | Items for Sale by private party | 24 | 07-31-2011 09:12 AM |
| Grounding Kit | EjDaPogi | Middle East | 43 | 03-30-2011 07:23 AM |
| Blending a Kit With a Factory Bezel | sqcomp | In Car Entertainment + Electronics (audio / video / alarm) | 6 | 05-02-2010 11:54 PM |
| GROUNDING KIT DIY? | SEaton | DIY / Maintenance / Service | 73 | 10-22-2006 04:03 PM |
