Old 02-14-2013, 09:47 PM   #1
UberSilver
UberSilver's Avatar
WhiteLine Sway, Soft/Hard what works for you?
So today I went to the hard setting on my WL sway bar. WOW! What a jump in performance! But a bit scary. If you doing 60~70 mph into a long sweeper, and you stay on the gas, it's down right dreamy. Once you let off the gas, mucho Oversteer! I would not try this in the rain. But its so close to the edge, it's a lot of fun.
I've put it back to the softer setting.
So what have all of you other WL bar users found with your settings?
Old 02-14-2013, 10:12 PM   #2
^ Same. According to Whiteline, the soft setting is like a 21mm bar, and the firm setting is like a 23mm bar.
22mm is actually between the two holes.
I've used both settings, autocross is pretty nice on soft, the Yaris lets off rear weight really easy, especially with a lightened flywheel.
Old 02-14-2013, 10:16 PM   #3
UberSilver
UberSilver's Avatar
So are you saying the 21mm would be better/safer for street?
Old 02-15-2013, 01:35 AM   #4
I think 21 would be, generally, safer for the streets. However, it comes down to how hard you drive/your driving style and other mods your car. I can push my car hard into a corner, and it'll slightly understeer. Blipping the gas really quickly and letting off completely brings it back to an almost neutral cornering.
I have the TRD rsb, GT-Spec rear sway link brace, front Tanabe strut bad, and TRD dampers with Tein S.Tech springs.
I think if you get any spring aside from the S.Tech's (I think they're the only ones that have a stiffer rear spring rate), it might help out with your off gas oversteer.
Old 02-15-2013, 11:06 AM   #5
Can't answer that question for all cars and all owners. Wheels, tires, driving style, and many more factors determine a driver's choice that "feels right".
You're more comfortable/feel more in control on the soft setting. Other drivers prefer the firm setting. Hard to say for everyone.
Old 02-15-2013, 12:09 PM   #6
UberSilver
UberSilver's Avatar
I talked with Whiteline Australia, and the bloke was really helpful. He stated with my stock tires and mildly stiff spring rate, I should NOT use the 22 mm setting! Saying the 21 mm setting is more than enough bar for my car.
Nice to get a 100% clear answer. Good people at WhiteLine, very happy with there product.
Whiteline sway help!! Deshi Basara DIY / Maintenance / Service 15 01-10-2013 06:25 PM
H+R springs and Whiteline sway bar (installed) BEEF Wheels, Tires and Suspension Forum sponsored by The Tire Rack 2 06-16-2012 11:53 PM
FS: whiteline adjustable sway bar netz2008 Items for Sale by private party 0 09-09-2011 12:27 PM
Gauging Interest: Whiteline Front/Back Adjustable Sway Bars RaptorRacing Wheels, Tires and Suspension Forum sponsored by The Tire Rack 35 12-15-2009 05:23 AM
