Old 03-08-2013, 02:05 AM   #1
lelsrud
Drives: 1,5 ts 2002
Rear fog light always on
Hi
I have a 2002 1,5 ts, 106bhp yaris.
For some time now my rear fog light has been switched on, both whith the ignition switched on and off.
I tried to check the fuses, but that seems okay. (Does anybody know exactly which fuse to check?)
It seems also that my front fog lights stopped working, almost the same time my rear light turned on.
Does anybody have a clue as to what might be wrong?
Thank you very much in advance for any answers.
lelsrud is offline   Reply With Quote
Old 03-08-2013, 06:28 AM   #2
Does you Yaris have daytime running lights, as the way the rear fog is wired is different for DRL versus non DRL Yaris?
Old 03-08-2013, 06:39 AM   #3
lelsrud
Drives: 1,5 ts 2002
Yup, my Yaris has DRL.
Old 03-08-2013, 07:49 AM   #4
OK. The rear fog light is fed from the front fog light relay, which is the relay stuck to the left side of the under dash fuse panel. I would start with pulling that relay out and slapping it against a hard surface with you hand. That will unstick the relay contacts if they are stuck. See if that makes the rear then not stay on with the car off.
For the fronts, I would suspect that the bulbs are burnt out.
Old 03-08-2013, 08:04 AM   #5
Kar98
Drives: 2011 Scion tC
I can't swear on it for Norway, but in Germany for instance, front fogs and rear fog light can be switched independently from each other.
Old 03-08-2013, 08:13 AM   #6
This is a first gen, not a second gen, so the wiring is a bit different. The way this is wired, if you turn on the switch for the rear, the fronts are automatically turned on as well, but the fronts can be on without the rear.
Old 03-10-2013, 05:46 PM   #7
lelsrud
Drives: 1,5 ts 2002
Tanks, i'll try that.
I think the relay-solution may apply to the front fog as well, cause its not the bulbs, it wont switch on at all...
Again, thanks for the possible solution.
Old 03-12-2013, 02:49 AM   #8
lelsrud
Drives: 1,5 ts 2002
Just one more question.
Shouldnt the fog light be turned off when i remove the relay?
I've removed, and slapped every relay in the under-dash fusebox.
But the fog light remained turned on all the time...
thank you again for any advice/suggestion.
Old 03-12-2013, 06:22 AM   #9
The relay is mounted to the side of the fuse box (like it was an afterthought). Are you sure you pulled that one?
Old 03-12-2013, 07:35 AM   #10
lelsrud
Drives: 1,5 ts 2002
This is my fuse box under the dash..
I've pulled all the relays i can see, but none of them made the light turn off.
Once again, thank you (and in advance for more tips)..
Old 03-12-2013, 11:25 AM   #11
The diagram below shows where the relay should be on your right hand drive Yaris:
Old 03-12-2013, 05:43 PM   #12
Kar98
Sounds about right. Also, I was referring to regulations, not particular models of cars. Rear fog lights are mandatory in many European countries ( I wanna say all of them, but I'm not sure), whereas front fog lights are optional.
Now depending on manufacturer, there are differences on how you can run front fogs in connection with main headlights. VW, BMW and Benz factory front fogs are switched so they turn off when you turn on high beams, but you have turn on at least the parking lights.
Renaults are wired to turn the rear fogs off when you restart he car, so you don't drive around blinding people behind you for weeks after you drove through some fog ;)
Ebay Fog Light Rant CTScott DIY / Maintenance / Service 65 06-13-2022 12:10 PM
Fog Light wiring Rammy DIY / Maintenance / Service 0 11-08-2012 08:34 PM
Any PICS of Fog Light SWITCH Location?? TRDMarty General Yaris / Vitz Discussion 7 05-29-2012 03:00 PM
WTB: Fog Light Switch or Stalk Lil Abner Willing to Buy by private party 4 08-20-2010 08:07 AM
