![]() Drives: 2008 Yaris T2 Join Date: Nov 2012
Fitting double din head unit
Hey all,
In need of a bit of help - I have a 2008 Toyota Yaris (UK) and I am planning on replacing the head unit. I currently have a W58824 and I have ordered a Parrot Asteroid Smart. (double din) I have also purchased this: (can't remember model number) ![]() Could anyone tell me what else I would need such as Wiring harnesses and ISO mounts? I am a complete beginner at this, but I would like to learn hence why I am trying this for myself. Thanks! |
If your new radio is double DIN and you ordered the 180mm opening trim, rather than the standard Toyota 200mm opening one, then you will not need the trim kit to fill the gap on either side.
For the wiring harness, you can pick up a generic Toyota one on ebay for $5 US or less, or the Metra 70-1761.
That's absolutely great!
Thanks for your help CTScott! :) |
Any idea why I would loose power to my center cluster dimmer knob and my a/c control knobs. I installed an aftermarket single din. Got all the right stuff. My dimmer doesn't work. And the lights for the a/c knobs don't light up anymore...
#5 | |
Mr. 155 and climbing
possibly a bad harness?
It sounds like the PANEL1 fuse in the under dash fuse panel is popped.
#7 | |
Did you disconnect your Ground battery terminal from the battery before attempting install ?
![]() ![]() Audio is under Construction Kenwood KDC-X794 Hifonics Zeus ZXI6.5C 6.5-Inch 2-Way Component Speaker System - AUTOTEK ATX65CX 6.5-Inch Hifonics BXi 1210D - Crunch PowerZone P1400.4 (2)12 inch Kicker CVR's - 0 gauge from battery to Distribution block - 4 Gauge Power/Grounds to amps - Duralast Yellow Top - Big 3 |
I did disconnect the battery. Ill check the fuses tomorrow.
Where can I find a diagram of that fuse panel?
| Tags |
| din, double, fitting, head, unit |
| Custron T1062TYT Review (Long) | mr.steevo | In Car Entertainment + Electronics (audio / video / alarm) | 1 | 11-24-2011 02:13 PM |
| reasonably priced double din head unit | BrazdonW | In Car Entertainment + Electronics (audio / video / alarm) | 4 | 11-12-2010 04:47 AM |
| For sale Pioneer double din head unit!! | 2009BBPliftback | Items for Sale by private party | 12 | 07-10-2009 12:21 AM |
| Sony XAVW1 double din head unit | Julz | In Car Entertainment + Electronics (audio / video / alarm) | 4 | 09-09-2007 09:27 PM |
