#1 | |
![]() ![]() ![]() ![]() ![]() ![]() Drives: 07 Yaris 3dr LB (Bayou Blue) Join Date: Oct 2008
Silly question ..... >.>
I know I can probably search this but I havnt posted up a thread in a while....
my car is well over 125k and well .... what major service is it in need of? I'm assuming the dreaded timing chain.... perhaps a transmission/coolant flush as Ive never had it done. I feel so bad for my yaris... I feel like I've neglected all it's service needs.... except I have been very good and given it full syn oil changes on schedule every 5k. Thanks for not flaming at me....
-Jen <3 ![]() Quote:
![]() Drives: 2011 Yaris Y Join Date: Jun 2013
replace oil,filters,spark plugs
Nov 2006
Drives: Vitz S1600 Join Date: Apr 2007
+1 replace trans/gear oil/ and coolant, maybe brake fluid and or pads if needed
Cold Air Induction|Blitz SUS POWER Air Cleaner System|2.4L 2AZ-FE Throttle Body|Blitz Compressor System|Full Light weight pulley kit|GReddy Ti-C exhaust System|Blitz Throttle Controller|T/B Coolant Bypass + Gasket Trimmed|Weight deduction|Exhaust Manifold|Center pipe|PCV Bypassed |
![]() ![]() Drives: 2007 Yaris LB Join Date: Mar 2011
The Yaris has a timing chain, not a belt like some other models. No need to change it.
Other than that, like others have stated, fluids, filters and plugs. That is about it. The Yaris does not require much in the way of scheduled maintenance and most of it can be done by the owner.
2007 LB W/Cold Wx Package |
Timing chains need to be replaced when they are worn. Usually you can hear if they are worn. There is a lot of clanking and what not. There is probably a schedule for that but I think our engines are non-interference motors anyway so if the chain lets loose, it won't hurt anything anyway (feel free to correct me as that would be good to know).
I know a guy that had a dodge dakota with 600,000+ miles on it with the original timing chain. He had a courier service. |
As long as you change the oil regularly, the timing chain should basically last the life of the car.
A certain amount of play in the chain is normal for it to still be in spec. The "1NZ-FE" is indeed a non-interference engine as are most of Toyota's engines.
![]() ![]() ![]() Drives: 2009 yaris 2 door Join Date: Feb 2013
timing chain
If you have 125k and never done any repairs you're doing goooood.
Tranny fluid and coolant flush sound about all you need to do for now and Have somebody check your ball joints,tie rod ends and shocks/struts to see if they need replacement. Do a front end alignment and sometimes those mechanics will inspect all your suspension and let you know what needs replacement. Have a brake shop inspect your brakes, especially the rear cause I believe those wear out faster on these front wheel drive cars. Good luck to ya I believe the timing chain is not due for replacement until 400-500k miles. and if you're conscientious about getting stranded I would replace the serpintene belt and battery if they are already 3-4 years old. |
Yes, I would definitely check/replace the serpentine belt if you haven't replaced it recently.
Although it wont cause any damage it it breaks, it will leave you "dead in the water" if it does . |
| silly spark plug question | ryota | DIY / Maintenance / Service | 11 | 08-25-2013 11:41 PM |
| Silly question? Does running higher PSI cause more wear-and-tear on suspension? | matti | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 11 | 09-28-2012 08:42 PM |
| Voltage regulator and Amperage question... | cr.chango | DIY / Maintenance / Service | 13 | 11-24-2009 12:59 PM |
| Amplifier Watt Question....noob question | hasher22 | In Car Entertainment + Electronics (audio / video / alarm) | 4 | 09-27-2007 03:59 PM |
| Silly Question | Nutzoids | General Yaris / Vitz Discussion | 2 | 05-15-2007 01:38 PM |
