![]() ![]() ![]() Drives: Yaris Hatchieback Join Date: Jun 2010
Vehicle Flick
While I was driving, the vehicle flick. The light goes off and come back right away. After it flick and I keep driving nothing happen again. This happened the past two day when I drive with the lights on.
Check battery is 12.85 voltage. When the vehicle is running is read 13.85 voltage. Current mileage 74k and replace OEM alternator 4k ago. Any idea???? Please help! |
Check the large connectors that plug into the battery terminals. In the past a couple of people have had issue with those connector pins being severely oxidized, causing similar behavior.
I will check them out this weekend. Thanks CTScott!
Dose the ground kit defect anything in the vehicle? I got a ground kit running in the vehicle. I notice the battery is needs to start the vehicle. Once the vehicle start is running by the alternator not the battery any more. Is that true ? |
#4 | |
CTScott, I had check everything and I dont see any wrong wit it. All ground cable is connect and tight. Could it be the ignition problem or air, fuel. Vehicle basic running on those three things. Either one failure can be the problem. ThX!
When you say it "flicks" do just the lights flicker, or does the engine stop running briefly?
It just complete lost everything for a sec and come back up. The first time happened to when I come to the stop light. The vehicle lost all the power and come back up in just sec. I can feel the steering wheel very hard to turn. The second time I was driving on the freeway. Suddenly the light was out and came back up.
If everything is cutting out, then I would not suspect ignition, fuel, etc., as the lights would still stay on if the engine itself cut out for a second. I would try wiggling connectors with it running, like the ignition switch connector, to see if you have a loose terminal.
![]() ![]() Drives: 08 Yaris AT, 350Z GT MT Join Date: Feb 2013
At 75k miles I would replace the battery (if you have not done so already).
As Scott said, carefully inspect the battery connectors, remove them both, (Ground first) and clean or replace them if need it. Clean the battery side as well. If the alternator was replaced, check the connections as well. Give Scott more info, if anyone can help you here, he is probably the ONE :) |
| 2012 Camry | Kal-El | Off-topic / Other Cars / Everything else Discussions | 26 | 10-02-2011 10:20 PM |
| 2012 Ford Focus ELECTRIC | Kal-El | Off-topic / Other Cars / Everything else Discussions | 11 | 02-11-2011 12:34 PM |
| Keep your vehicle protected! | sqcomp | In Car Entertainment + Electronics (audio / video / alarm) | 17 | 09-10-2009 03:02 AM |
| Dealer: Disabling the seat belt chime is now illegal? | schleppy | Cosmetic Modifications (Exterior/Interior) | 13 | 04-18-2009 05:43 PM |
| problem car | conurebuddy | General Yaris / Vitz Discussion | 23 | 04-11-2009 01:37 AM |
