Old 03-28-2013, 09:23 AM   #1
Squishy
Drives: 2012 Yaris LE 4dr
33% reduction in mileage?
I wanted to post some experience on here that could potentially help someone here. My previous car was a 5spd Scion xB, of course it was also 1nzfe powered. At around 50k miles my fuel mileage nose dived from 30-32 to 21-22. and it wasn't a fluke, it lasted for 6 months. I took a 6 hour trip to Dallas and 22 was all it would muster. I tried a tune up and it did nothing (btw if you haven't figured it out yet stay away from e3's). I had no check engine lights and no warnings signs, I mean the car was still running great. So I went to work for O'Reillys and one day we got to talking about the issue I was having. One of the guys suggested I try Seafoam. I used the throttle body cleaner that uses a curved nozzle to spray into the intake while its running and I put a bottle in the tank. Instantly it jumped back to 29mpg and averaged 27-28. for the next 2 years and 30k miles of ownership. I did add a can of Seafoam every other oil change. Also don't panic if you run Seafoam through the intake in this way and it looks like you blew a set of rings...lol this is normal. However you should have seen my face when I did this to mine without that little tid bit of knowledge.....lol PRICELESS!
Squishy is offline   Reply With Quote
Old 03-28-2013, 01:28 PM   #2
caineroad
caineroad's Avatar
Drives: 06 Yaris HB CE
would rather do a EFI cleaning instead.
caineroad is offline   Reply With Quote
Old 03-28-2013, 01:47 PM   #3
Yup, I Seafoam my car once a year with my annual oil changes. lol. I think my engine has been cleaned to the point where the smoke that comes out is only the burning of the Seafoam itself. =)
Old 03-28-2013, 07:23 PM   #4
UberSilver
UberSilver's Avatar
Drives: 08Yaris2D, 88LandCruiser.
First post about seafoam, I call
And there's no product on earth that will give you a 6 mpg boost.
UberSilver is offline   Reply With Quote
Old 03-29-2013, 09:11 PM   #5
daf62757
Nothing beats a Toyota!
daf62757's Avatar
Drives: 2013 Yaris 5 dr liftback
So do you put the Seafoam in the gas tank or spray it into the intake?
Big Dave
Indianapolis, IN
Synthetic Oil....its in my car.....for at least 10,000 miles!
daf62757 is offline   Reply With Quote
Old 04-02-2013, 03:01 PM   #6
Amdkt7
Returning to Toyota
Drives: 2013 L 3dr MT
Sure there are many products that can boost FE, if there is something wrong, and the product fixes it. Otherwise, you are quite correct.
Amdkt7 is offline   Reply With Quote
Old 04-03-2013, 11:41 AM   #7
jambo101
jambo101's Avatar
Drives: yaris 08 sedan
I'd strongly suspect the math formula you are using to derive those low numbers. And if they are in fact in the low 20's Seafoam while somewhat beneficial aint going to fix the problem of you getting half the mpg you are supposed to be getting....
Hows the mpg in your 2012 Yaris LE 4dr?
Have Yaris will travel..
Old 04-03-2013, 11:05 PM   #8
screenprintr
screenprintr's Avatar
Drives: 2010 Toyota Yaris
Someone said a Prius gets like 50 mpg/volts.
screenprintr is offline   Reply With Quote
Old 04-08-2013, 12:27 AM   #9
why?
Only Happy When it Rains
why?'s Avatar
Drives: Yaris LB
so have you changed your transmission fluid? That really hits gas mileage, and hit me at about 55k.
Colin Chapman disciple
-Mileage Thread- -Log your mileage, year, model, color, any problems here... Kal-El DIY / Maintenance / Service 322 07-20-2016 11:07 AM
Amazing Gas Mileage .. way too easy. edmscan Fuel Economy Forum 9 07-19-2012 07:36 PM
Does Gas Mileage Increase After 1st Oil Change? ChilliwackGuy Fuel Economy Forum 10 08-04-2010 03:13 PM
2009 Yaris Mileage wornways Fuel Economy Forum 3 07-29-2009 12:42 PM
Performance mods that won't affect/will hardly affect gas mileage?? Mr.Yaris Performance Modifications 15 07-30-2007 01:32 AM
