![]() Drives: n/a Join Date: Apr 2013
Hello guys!
I don't own a yaris buuuuut I'm interested in trying to swap the Yaris engine into my KP61 starlet. I know I know that the most popular swaps are 4ag or 13b rotary but I kinda wanted to stay as close as possible to it's 1.3L roots! And so the yaris is what I have in mind.. My questions are many but here's a few! 1. What would I have to modify on the engine to make it from fwd to rwd? 2. Anyone know of a rwd transmission that would be a straight bolt-on? 3. Even better has anyone performed this on any other car from fwd to rwd? My Yaris gurus! I seek your knowledge and guidance! The Yaris engine would be an awesome upgrade if you consider that the original 4K-C engine only made: The 1981 and 1982 California-spec 4K-C produced 58 hp (43 kW) at 5200 RPM and 67 lb·ft (90 Nm) at 3600 RPM. |
There is a dedicated thread for motor swap discussions:
http://www.yarisworld.com/forums/showthread.php?t=15242
#3 | |
I saw it but it's more geared towards swaps for the yaris! I wanna swap the yaris engine onto my starlet!
I'll repost and see what happens! Quote:
やりすぎだ~
The 4AGE would be the easiest, most affordable, least modifications, most parts available, etc.. Besides, the 2NZFE is 1.5L, closer to a 1.6L 4AGE than a 1.3L 4KC. How about a 1.2L 3KC? That's closer to the Starlet roots. Don't mean to discourage you but trying to install a 2NZFE into your Starlet will require a lot of $$$ to modify it to fit into you vehicle. Good luck if you ever even attempt it.
You could do it with custom mounting and if you take the transmission apart and weld the diff you could use it. You'd just need to make a cover for the open side and a custom driveshaft.
| NEED ENGINE CHECK LIGHT CODE LIST | Attitude | Forced Induction Forum | 12 | 04-11-2011 07:38 PM |
| Toyota Yaris Engine Map | wariss | Performance Modifications | 5 | 03-15-2009 01:21 PM |
