![]() ![]() ![]() ![]() Drives: 06 Yaris HB CE Join Date: Aug 2009
handbrake warning alarm??
anyone know if it is possible install a handbrake warning alarm to prevent driving while the handbrake is on?
I thought all yaris came with one already I found out mine had one when I was driving testing the hand brake it started beeping like crazy till it was released
No my doesn't, I have a hatchback not sedan though maybe it's diff?
My girlfriend has a 09 hb and hers has a chime too it sounds like the seat belt chime
http://www.yarisworld.com/forums/showthread.php?t=12101
Not all Yaris have the handbrake alarm. See above click. If anyone know how to install one ? I assume just connecting the handbrake light or wire to the seat belt chime? |
![]() ![]() ![]() ![]() Drives: 2011 Scion tC Join Date: Jul 2012
Your parking brake alert should be that you're not going anywhere ;)
The parking brake switch has one yellow wire. When the brake is up that wire gets grounded, so you can install a 12V beeper and connect its + lead to ignition switched power and its - lead to that yellow wire.
#8 | |
#9 | |
Is it possible to make something that only beeps when car is driving? |
#10 | |
It would be possible to make one that only beeps when the car is moving, but that would take a bit of extra electronics to do so.
#11 | |
Similarly the seat belt chime only sound when the speed is over 20km/h(equivalent to xx miles), if it is easier, how possible is it to hook up the handbrake wire to seat belt chime? I would really like to have one that works only when the car is moving, can you briefly explain where i have to connect to make this work, I will try my best to figure it out myself. Thanks |
#12 | |
Bridging the seatbelt and ebrake would be way more difficult than adding a motion based signal to the ebrake. If you want to experiment with a beeper, tie the - side to the yellow wire on the ebrake switch and the + side to the pink wire on the ignition switch connector.
#13 | |
But I will try experiment with the beeper like you suggested, thanks |
I kind of found a solution, it may work ok, but not what it ideally for
I will bridge a motion sensor with delay timer... let's see if this will work well |
You would be better off with an accelerometer. The Yaris vibrates more when stationary than when it is moving.
#16 | |
Accelerometer is good idea, let me see what ebay has to offer. |
I could actually make you a device that works off the VSS (speed sensor) wire. My Demetricifier (which lets a km cluster work as a Mile one) interprets that signal, so driving a beeper instead of manipulating that signal would be very easy.
#18 | |
| Factory Alarm on my '08 Liftback is Too Sensitive! | alex_melodymaker | In Car Entertainment + Electronics (audio / video / alarm) | 9 | 06-07-2011 04:21 PM |
| Alarm Wiring Advise Needed | Lil Abner | In Car Entertainment + Electronics (audio / video / alarm) | 14 | 09-26-2010 11:11 AM |
| Keep your vehicle protected! | sqcomp | In Car Entertainment + Electronics (audio / video / alarm) | 17 | 09-10-2009 03:02 AM |
| help me with my annoying alarm! | misteo | In Car Entertainment + Electronics (audio / video / alarm) | 1 | 10-21-2008 02:49 PM |
| Rant! Damn car alarm installers, trying to rip me off!!!! | W.A.S.P | In Car Entertainment + Electronics (audio / video / alarm) | 18 | 11-21-2006 10:18 PM |
